Ana içeriğe geç
2002 Kawasaki KLR650 Carburetor Rebuild
Neye ihtiyacın var
  1. 2002 Kawasaki KLR650 Carburetor Rebuild, 2002 Kawasaki KLR650 Carburetor Rebuild: adım 1, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild, 2002 Kawasaki KLR650 Carburetor Rebuild: adım 1, 2 resimden 2.
    • Use an 3 mm Allen wrench to loosen the drain screw on lower portion of bowl.
    • Remove old fuel left inside of bowl.
  2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 2, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the four screws on the outside of the bowl.
    • Remove the bowl from the carburetor and take out the gasket from the bowl.
  3. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 3, 3 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 3, 3 resimden 2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 3, 3 resimden 3.
    • Remove the pilot jet using a flat head screwdriver.
  4. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 4, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 4, 2 resimden 2.
    • Remove the main jet using a flat head screwdriver.
  5. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 5, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 5, 2 resimden 2.
    • Remove the main jet sleeve using an 8 mm combination wrench.
  6. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 6, 3 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 6, 3 resimden 2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 6, 3 resimden 3.
    • Push out the retaining pin holding in the float and float seat.
    • Remove this assembly from the carburetor.
  7. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 7, 3 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 7, 3 resimden 2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 7, 3 resimden 3.
    • Flip the carburetor around and remove the four screws securing the top housing using a Phillips #1 screwdriver.
    • Note that this is spring loaded.
  8. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 8, 3 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 8, 3 resimden 2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 8, 3 resimden 3.
    • Pull up on the diaphragm carefully to remove the diaphragm and slide.
    • Take out the needle and plastic needle retainer.
  9. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 9, 3 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 9, 3 resimden 2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 9, 3 resimden 3.
    • Replace the needle and reassemble the slide.
    • Insert the slide assembly back into the carburetor.
    • The needle needs to be lined up with the hole in the carburetor. Make sure that the diaphragm makes a good seal in the carburetor gasket groove.
    • Insert the spring into the slide assembly and put the plastic housing back on.
    • Maintain pressure while screwing the four Phillips screws in the housing since it is spring loaded.
    • Tighten the screws in a diagonal pattern to ensure that the plastic housing is sealed properly.
  10. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 10, 3 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 10, 3 resimden 2. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 10, 3 resimden 3.
    • Place the new float seat onto the float.
    • Place the float assembly into the carburetor and slide the retaining pin back into its hole to secure the assembly.
    • Make sure that the float can move freely.
  11. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 11, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 11, 2 resimden 2.
    • Insert the new pilot jet into the carburetor. Tighten it with a flathead screwdriver.
    • Do not over tighten the pilot jet as it is made of brass and may strip easily.
  12. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 12, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 12, 2 resimden 2.
    • Reinsert the main sleeve and tighten with an 8 mm combination wrench.
    • Insert the new main jet into the main jet sleeve. Tighten using a flathead screwdriver.
    • Do not over tighten as this is made out of brass and may strip easily.
  13. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 13, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 13, 2 resimden 2.
    • Insert the new gasket into the bowl gasket groove.
    • Use a Phillips #1 screwdriver to replace the four screws securing the bowl to the carburetor.
    • Tighten in a diagonal pattern to ensure that the bowl is sealed properly.
  14. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 14, 2 resimden 1. 2002 Kawasaki KLR650 Carburetor Rebuild: adım 14, 2 resimden 2.
    • Use a 3 mm Allen wrench to tighten drain screw at the bottom of carburetor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shawn Marcoux
253 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 63
Her zaman: 1,655
