Ana içeriğe geç
2002 Nissan Altima Hubcap Replacement
Neye ihtiyacın var
  1. 2002 Nissan Altima Hubcap Replacement, Hubcap: adım 1, 3 resimden 1. 2002 Nissan Altima Hubcap Replacement, Hubcap: adım 1, 3 resimden 2. 2002 Nissan Altima Hubcap Replacement, Hubcap: adım 1, 3 resimden 3.
    • Attach the retention ring to your new hubcap, aligning the divot in the ring with the tire-valve cutout.
    • Be sure to click the ring in each clip around the hubcap.
  2. 2002 Nissan Altima Hubcap Replacement: adım 2, 1 resimden 1.
    • Use a wide tipped removal tool to align the wedge inside the hubcap.
    • You may be able to remove the hubcap with your hands if you grab and pull. Be careful, though, to not injure yourself.
  3. 2002 Nissan Altima Hubcap Replacement: adım 3, 1 resimden 1.
    • Gently push on the solid parts of the hubcap until they pop out of the tire.
  4. 2002 Nissan Altima Hubcap Replacement: adım 4, 2 resimden 1. 2002 Nissan Altima Hubcap Replacement: adım 4, 2 resimden 2.
    • Align the replacement hubcap with the tire valve.
    • There should be a cutout in the hubcap to specifically fit around the tire valve.
  5. 2002 Nissan Altima Hubcap Replacement: adım 5, 2 resimden 1. 2002 Nissan Altima Hubcap Replacement: adım 5, 2 resimden 2.
    • Keeping alignment, hold the center of the hubcap and forcefully push in all the sides of the inner ring until it secures in place.
  6. 2002 Nissan Altima Hubcap Replacement: adım 6, 1 resimden 1.
    • Repeat steps 1-5 for other three tires.
Bitiş Çizgisi
Bre Sanders
133 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-6, Whithaus Spring 2024 UC Davis, Team 2-6, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S2G6
2 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 84
