Ana içeriğe geç
2003-2011 Honda Element Spark Plug Replacement
Neye ihtiyacın var
  1. 2003-2011 Honda Element Spark Plug Replacement, Spark Plugs: adım 1, 1 resimden 1.
    • Pull hood latch release, located on the base of the A-Pillar.
    • Pull up on the release lever between the hood and grille, it is located on the left.
    • Lift hood and engage the hood prop rod inside the provided notch hole on the edge of the hood.
  2. 2003-2011 Honda Element Spark Plug Replacement: adım 2, 1 resimden 1.
    • Disconnect negative (-) battery terminal from the battery.
    • Place the now free negative (-) battery cable behind the battery itself so it cannot easily re-connect itself.
  3. 2003-2011 Honda Element Spark Plug Replacement: adım 3, 1 resimden 1.
    • Remove the 4 10mm acorn nuts from the plastic engine cover plate. Set nuts aside for reassembly.
    • Remove the plastic coverplate and set aside.
  4. 2003-2011 Honda Element Spark Plug Replacement: adım 4, 1 resimden 1.
    • Using the 10mm socket and ratchet, remove the 4 bolts holding down the coilpacks. You may need the 10mm wrench if your socket is not deep enough to contact the hex section of the stud.
  5. 2003-2011 Honda Element Spark Plug Replacement: adım 5, 1 resimden 1.
    • Pull up on coilpack lightly, it should release easily from the spark plug below.
    • Using your thumb and forefinger, grasp the connector, pushing down the latch with your thumb.
    • Wiggle and pull the connector off of the coilpack, it will have some resistance.
    • If the connector does not release, try pushing connector in, then pushing the latch and pulling on the connector.
    • Note: Do not pull by the wires.
  6. 2003-2011 Honda Element Spark Plug Replacement: adım 6, 1 resimden 1.
    • Remove all the coilpacks and set aside.
    • Using the 3/8" Ratchet with Socket Wrench Extension, 3/8" Drive and 5/8" Spark Plug socket, remove the 4 spark plugs from the spark plug wells. They should require some force but unscrew easily after the initial turns.
  7. 2003-2011 Honda Element Spark Plug Replacement: adım 7, 1 resimden 1.
    • Remove new spark plugs from box. Apply anti-seize to the spark plug threads ONLY, carefully wipe off any excess that touches the ceramic insulator or the tip contact.
    • Now apply dielectric grease to the contact tip and the first 1/2" of the ceramic insulator.
  8. 2003-2011 Honda Element Spark Plug Replacement: adım 8, 1 resimden 1.
    • Using the spark plug socket, put each spark plug into their hole and thread in hand tight.
    • Tighten all 4 plugs 1/2 turn past hand tight.
  9. 2003-2011 Honda Element Spark Plug Replacement: adım 9, 1 resimden 1.
    • Reinstall the coilpack 3/4 of the way into the hole, then push on the electrical connector until it clicks.
    • Push the coilpack down the rest of the way into the spark plug well, you should feel a slight click as the coilpack connects to the contact of the spark plug
    • Repeat these same steps for the remaining 3 coilpacks.
  10. 2003-2011 Honda Element Spark Plug Replacement: adım 10, 2 resimden 1. 2003-2011 Honda Element Spark Plug Replacement: adım 10, 2 resimden 2.
    • Using the 10mm socket and 3/8" ratchet, install bolts on the #1 (from left) and #3 coilpack. They should be 1/4 turn past finger tight.
    • Install the studs on #2 and #4 coilpacks.
    • Reinstall coilpack cover, using the 4 acorn nuts removed previously.
  11. 2003-2011 Honda Element Spark Plug Replacement: adım 11, 1 resimden 1.
    • Reinstall the negative (-) battery terminal, tightening with the 10mm wrench or 10mm ratchet.
  12. 2003-2011 Honda Element Spark Plug Replacement: adım 12, 1 resimden 1.
    • Remove hood prop rod from the hood, flip down and connect it into its stay.
    • Shut hood lightly, then push down to engage the main latch.
  13. 2003-2011 Honda Element Spark Plug Replacement: adım 13, 1 resimden 1.
    • Using the code written in your Service History booklet (the Pre-Delivery Inspection page should have it), key in the radio code using the preset buttons.
    • Don't forget to mark down that you serviced the spark plugs in the Service History booklet!
Sonuç
This is a great job to do to save some money, its involved enough to be entertaining but not enough to be scary.
9 farklı kişi bu kılavuzu tamamladı.
Niklas Johnson
1.207 İtibar
18 adet Kılavuz yazıldı
4 Yorum
I torqued the spark plugs to 13 ft lbs.
Luke Janavicius - Yanıt
You put quite a bit of effort into creating this extremely helpful guide. I hope others appreciate all of your hard work. Thank you so much for doing a terrific job and making the world a better place.
Michael Huskey - Yanıt
Thank you for this! Much appreciated- saved me so much money and learned how to do it myself :)
Cheers!
Pauly Bonz - Yanıt
Thorough and complete walk-thru on this task. Well done!
Conrad Deetjen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 118
Her zaman: 30,977
