Giriş
The 1st-generation Pontiac Vibe takes advantage of a dual-filament tail light bulb, which means a single bulb is responsible for both the running tail lights and the brake lights. One or both of the filaments in the bulb can burn out, requiring replacement of the entire bulb.
It’s best to replace both the left and right side bulbs at the same time, even if only one is burned out. This ensures the brightness level of both bulbs are identical. Plus, most replacement bulbs come in pairs of two anyway.
Neye ihtiyacın var
Begin by opening up the rear hatch door by reaching under the "Pontiac" logo and pressing on the rear hatch door button.
Pull on the door from the same location to open the rear hatch.
5 farklı kişi bu kılavuzu tamamladı.
3 Yorum
How do I replace the 3rd brake light?
What about the 3rd bulb
Thank you. I need to connect a backup camera, I am getting old; forgot a few things ! he he...nice job you did with your camera
