Giriş
Brake pad life varies greatly by driving style and car use. There is no specific mile count at which brake pads should be changed. The best indicator of worn brake pads is a screeching sound when braking. It is recommended that you change your brake pads when this occurs.
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Once car is raised, remove the lug nuts on one of the front tires with the 3/4'' socket.
25 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Safety tip - before lifting the car up with the jack, break loss the lug nuts as in step 5, break lose means to get them started but they are still snug. Why - This way you don't have to crank with strength when the car is on the stands and possibly knock it off the stands.
