Ana içeriğe geç
2003-2007 Honda Accord Interior Door Handle Replacement
Neye ihtiyacın var
  1. 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: adım 1, 3 resimden 1. 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: adım 1, 3 resimden 2. 2003-2007 Honda Accord Interior Door Handle Replacement, Interior Door Handle: adım 1, 3 resimden 3.
    • Open the appropriate side door of your vehicle that requires a door handle replacement.
    • Locate the tab on the panel behind the door handle.
    • Use a flat-head screwdriver (1 x 3 mm) to move the tab to the right and slightly pull the panel out.
  2. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 2, 3 resimden 1. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 2, 3 resimden 2. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 2, 3 resimden 3.
    • Locate two (2) Phillips head screws behind the door handle.
    • Remove the two Phillips head screws (1.6 x 1.3 x 10.16 mm) using a Phillips head screwdriver (1 x 3 mm).
  3. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 3, 3 resimden 1. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 3, 3 resimden 2. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 3, 3 resimden 3.
    • The first image shows the approximate location of 3 tabs behind the door handle assembly. Knowing the location of tabs is useful when attempting to release assembly.
    • Using your left hand, pull the assembly to the left to reveal the tab on the right. While pulling on the assembly, use a flat-head screwdriver (1 x 3 mm) to press the tab inward to release.
    • Once the tab on the right is released, a slight pull of assembly will release it from the door.
  4. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 4, 3 resimden 1. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 4, 3 resimden 2. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 4, 3 resimden 3.
    • Rotate the door handle assembly for ease of access to clips
    • Locate the first clip holding the door cable.
    • Rotate the clip clockwise to unlock the cable.
    • Once unlocked, pull the cable end from the holder.
  5. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 5, 2 resimden 1. 2003-2007 Honda Accord Interior Door Handle Replacement: adım 5, 2 resimden 2.
    • Locate the second clip holding the door cable.
    • Using a flat-head screwdriver (1 x 3 mm), release the clip.
    • Once the cable is released, the assembly is free to remove.
Sonuç
To install your new door handle assembly, follow these instructions in reverse order.
Additional tips: For step 5, the clip will be pushed back into the clip holder. For step 4, replace the cable and rotate the clip clockwise.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 111
