Ana içeriğe geç
2003-2007 Honda Accord Key Fob Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 2. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 2, 3 resimden 1. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 2, 3 resimden 2. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 2, 3 resimden 3.
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 3, 3 resimden 1. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 3, 3 resimden 2. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 3, 3 resimden 3.
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 4, 3 resimden 1. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 4, 3 resimden 2. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 4, 3 resimden 3.
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 5, 3 resimden 1. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 5, 3 resimden 2. 2003-2007 Honda Accord Key Fob Battery Replacement: adım 5, 3 resimden 3.
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
eCuration
378.307 İtibar
236 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
Bir Yorum
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 264
Son 30 gün: 1,268
Her zaman: 145,093
