Giriş
If your 2003-2007 Honda Accord key fob operates intermittently, the battery may need to be replaced. Use this guide to replace the battery in a 2003-2007 Honda Accord keyless fob remote.
Alternatively, follow the video tutorial from YouTuber NutzAboutBolts to complete the battery replacement.
Neye ihtiyacın var
Videoya Genel Bakış
Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
