Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will walk you through the process of replacing a malfunctioning crankshaft position sensor. The reason you would be replacing your crankshaft position sensor is because your car's "check engine" light is on and your car is running poorly. Again you can't conclude you have a malfunctioning crankshaft position sensor until you use a device to read the car's computer system.
Neye ihtiyacın var
Place the jack under the frame directly behind the left front wheel.
Once you have safely prepared the jack, rotate the jack's handle clockwise until it reaches a height of at least 20 inches. Leave enough space to safely move underneath the car. If more space is needed increase the height of the jack.
Lay under the car and locate the crank shaft position sensor. The sensor is located between the engine and the transmission near the front driver's side wheel. It is directly behind the rack and pinion.
Use the 10mm wrench or socket wrench to loosen the 10mm Hex Head bolt attaching the crankshaft position sensor to the car. If the bolt is rusted use a penetrating lubricant to remove the rust.
After you have removed the 10mm Hex Head bolt on the sensor, pull the sensor out of place with some force. (The sensor should pop right out)
Unplug the sensor from the wiring harness by squeezing the release clip and pulling firmly on the sensor.
4 farklı kişi bu kılavuzu tamamladı.
