Ana içeriğe geç
2003 Toyota Solara Tail Light Replacement
Neye ihtiyacın var
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: adım 1, 1 resimden 1.
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: adım 2, 3 resimden 1. 2003 Toyota Solara Tail Light Replacement: adım 2, 3 resimden 2. 2003 Toyota Solara Tail Light Replacement: adım 2, 3 resimden 3.
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: adım 3, 2 resimden 1. 2003 Toyota Solara Tail Light Replacement: adım 3, 2 resimden 2.
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: adım 4, 2 resimden 1. 2003 Toyota Solara Tail Light Replacement: adım 4, 2 resimden 2.
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: adım 5, 3 resimden 1. 2003 Toyota Solara Tail Light Replacement: adım 5, 3 resimden 2. 2003 Toyota Solara Tail Light Replacement: adım 5, 3 resimden 3.
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: adım 6, 2 resimden 1. 2003 Toyota Solara Tail Light Replacement: adım 6, 2 resimden 2.
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
Sonuç
To reassemble the tail lamp, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Melissa Spinali
110 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G2, Cole Spring 2017 UC Davis, Team S2-G2, Cole Spring 2017 üyesi
UCD-COLE-S17S2G2
3 Üyeler
1 Kılavuz yazıldı
1Rehber Yorum
How to replace the rear mount light in the rear windows of a 2009 toyota corolla
lincoln mcgill - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 122
Her zaman: 3,380
