Ana içeriğe geç
2004-2013 BMW 3 Series Inner Taillight Replacement
Neye ihtiyacın var
  1. 2004-2013 BMW 3 Series Inner Taillight Replacement, Inner Taillight Housing: adım 1, 2 resimden 1. 2004-2013 BMW 3 Series Inner Taillight Replacement, Inner Taillight Housing: adım 1, 2 resimden 2.
    • Unlock your trunk.
    • This can be done with either the remote or the trunk release button located on the driver's side footwell area.
    • Using the trunk handle, lift the trunk to it's highest position.
  2. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 2, 3 resimden 1. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 2, 3 resimden 2. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 2, 3 resimden 3.
    • Using the appropriate trim tool, carefully remove all ten rivets from the trunk liner.
  3. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 3, 3 resimden 1. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 3, 3 resimden 2. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 3, 3 resimden 3.
    • Pull on the green tab to release the inner trunk release handle.
    • After this, the trunk liner should be loose.
    • Carefully remove the liner and put it off to the side for later reassembly.
  4. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 4, 3 resimden 1. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 4, 3 resimden 2. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 4, 3 resimden 3.
    • Using either a 10 mm socket or an open-end 10 mm wrench, turn the nut counterclockwise to loosen it and remove the bracket that secures the inner taillight.
    • An open-end wrench was used in this guide, however, both tools work for removing the retaining nut.
  5. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 5, 2 resimden 1. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 5, 2 resimden 2.
    • From underneath the inner taillight, push the housing with enough upward force to separate it from its socket.
    • Be careful when pushing the housing, as the connector is still attached to the inner taillight.
  6. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 6, 3 resimden 1. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 6, 3 resimden 2. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 6, 3 resimden 3.
    • Tilt the inner taillight enough to gain access to the connector on the underside.
    • Firmly press the locking tab in the center of the connector.
    • Pull downwards on the connector to disconnect the inner taillight housing.
  7. 2004-2013 BMW 3 Series Inner Taillight Replacement: adım 7, 1 resimden 1.
    • Prepare your new taillight for reassembly.
    • Responsibly recycle your old inner taillight if it is no longer functional.
Sonuç
To reassemble the inner taillight, follow these instructions in reverse order.
Jason Tech Tips
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 317
