Ana içeriğe geç
2004-2008 Mazda RX-8 Battery Replacement
Neye ihtiyacın var
  1. 2004-2008 Mazda RX-8 Battery Replacement, Battery: adım 1, 3 resimden 1. 2004-2008 Mazda RX-8 Battery Replacement, Battery: adım 1, 3 resimden 2. 2004-2008 Mazda RX-8 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Find black tabs that lock Battery cover into place.
    • The tabs should snap off easily.
  2. 2004-2008 Mazda RX-8 Battery Replacement: adım 2, 2 resimden 1. 2004-2008 Mazda RX-8 Battery Replacement: adım 2, 2 resimden 2.
    • Use the 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
    • It is vital to disconnect the negative terminal before interacting with the battery. Make sure not to bridge the two terminals with your wrench or other tools.
    • Remove the terminals once nuts are completely loose.
  3. 2004-2008 Mazda RX-8 Battery Replacement: adım 3, 1 resimden 1.
    • Remove Battery terminals.
  4. 2004-2008 Mazda RX-8 Battery Replacement: adım 4, 1 resimden 1.
    • Using the 10mm Wrench remove gold nuts that hold the retention bar in place.
  5. 2004-2008 Mazda RX-8 Battery Replacement: adım 5, 1 resimden 1.
    • After removing the bar pull the dead battery out using the black straps.
Sonuç
After replacing the device, follow these instructions in reverse order to secure a new battery in its place.
2 farklı kişi bu kılavuzu tamamladı.
Gerrit Mouw
253 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-4, Regan Spring 2015 Cal Poly, Team 8-4, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G4
5 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Thanks!...Ron
sgt.splem - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 15,762
