Ana içeriğe geç
2004-2006 Scion xB Hatch Handle Replacement
Neye ihtiyacın var
  1. 2004-2006 Scion xB Hatch Handle Replacement, Hatch Handle: adım 1, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement, Hatch Handle: adım 1, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement, Hatch Handle: adım 1, 3 resimden 3.
    • Open the trunk of the car and locate the 13 clips holding the panel on.
  2. 2004-2006 Scion xB Hatch Handle Replacement: adım 2, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 2, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 2, 3 resimden 3.
    • Push the clip remover under the panel and pry to remove them.
    • Repeat for all 13 locking caps.
  3. 2004-2006 Scion xB Hatch Handle Replacement: adım 3, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 3, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 3, 3 resimden 3.
    • Use a small flathead screwdriver to depress and release the blue clip.
    • Grip the connector and pull the cable directly out of its port.
  4. 2004-2006 Scion xB Hatch Handle Replacement: adım 4, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 4, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 4, 3 resimden 3.
    • Use a small flathead screwdriver to depress and release the white clip.
  5. 2004-2006 Scion xB Hatch Handle Replacement: adım 5, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 5, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 5, 3 resimden 3.
    • Grab onto the blue cable and twist 90 degrees counter clockwise.
    • Pull out to detach from holding.
  6. 2004-2006 Scion xB Hatch Handle Replacement: adım 6, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 6, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 6, 3 resimden 3.
    • Grab onto the white cable and twist 90 degrees counter clockwise.
  7. 2004-2006 Scion xB Hatch Handle Replacement: adım 7, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 7, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 7, 3 resimden 3.
    • Grip the nut with pliers.
    • Rotate the pliers counter clockwise until the nut is removed.
  8. 2004-2006 Scion xB Hatch Handle Replacement: adım 8, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 8, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 8, 3 resimden 3.
    • Repeat the previous step for the other nut.
  9. 2004-2006 Scion xB Hatch Handle Replacement: adım 9, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 9, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 9, 3 resimden 3.
    • Push the rubber seal through the hole to the other side using a plastic tool.
    • If using a metal tool, take care not to scratch the metal.
  10. 2004-2006 Scion xB Hatch Handle Replacement: adım 10, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 10, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 10, 3 resimden 3.
    • While holding on to the handle assembly, gently pull out the cables to attached to the handle.
    • Remove the handle assembly.
  11. 2004-2006 Scion xB Hatch Handle Replacement: adım 11, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 11, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 11, 3 resimden 3.
    • Remove the two Phillips screws using a screw gun or a screw driver.
  12. 2004-2006 Scion xB Hatch Handle Replacement: adım 12, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 12, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 12, 3 resimden 3.
    • Use pliers to squeeze the two sides of the plastic clip together.
    • Use a pry tool to lever the tab out of its socket.
    • Repeat the previous two bullets on the right side to detach the button.
  13. 2004-2006 Scion xB Hatch Handle Replacement: adım 13, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 13, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 13, 3 resimden 3.
    • Gently clamp the pliers onto the lightbulb socket rubber, to the right of the button.
    • Rotate the pliers counterclockwise.
    • Wiggle the lightbulb socket out of its housing.
  14. 2004-2006 Scion xB Hatch Handle Replacement: adım 14, 2 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 14, 2 resimden 2.
    • Release the right bulb wiring from the channel it sits it.
    • This may require some force.
  15. 2004-2006 Scion xB Hatch Handle Replacement: adım 15, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 15, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 15, 3 resimden 3.
    • Gently clamp the pliers onto the lightbulb socket rubber, to the left of the button.
  16. 2004-2006 Scion xB Hatch Handle Replacement: adım 16, 2 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 16, 2 resimden 2.
    • Release the left bulb wiring from the channel it sits it.
  17. 2004-2006 Scion xB Hatch Handle Replacement: adım 17, 1 resimden 1.
    • Remove the button, the lightbulbs, and the wiring from the old hatch handle.
  18. 2004-2006 Scion xB Hatch Handle Replacement: adım 18, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 18, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 18, 3 resimden 3.
    • Use a Phillips head screwdriver to remove the screw on the light cap.
  19. 2004-2006 Scion xB Hatch Handle Replacement: adım 19, 2 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 19, 2 resimden 2.
    • Remove the lightbulb cap.
    • Repeat the previous step and then this step with the other cap.
  20. 2004-2006 Scion xB Hatch Handle Replacement: adım 20, 1 resimden 1.
    • All the attachments are removed from the old hatch handle, ready to reassemble onto the new hatch handle.
    • The rest of the guide demonstrates the reassembly procedure.
  21. 2004-2006 Scion xB Hatch Handle Replacement: adım 21, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 21, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 21, 3 resimden 3.
    • Insert the lightbulb cap into place on the right side of the new hatch handle.
  22. 2004-2006 Scion xB Hatch Handle Replacement: adım 22, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 22, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 22, 3 resimden 3.
    • Screw in the Phillips screw with your screw gun.
    • Repeat the previous step and then this step for the left cap.
  23. 2004-2006 Scion xB Hatch Handle Replacement: adım 23, 1 resimden 1.
    • Align the button, the lightbulb, and the wiring attachment.
  24. 2004-2006 Scion xB Hatch Handle Replacement: adım 24, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 24, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 24, 3 resimden 3.
    • Insert the left lightbulb socket to the left of the button.
    • Use your pliers to gently rotate the lightbulb socket clockwise into place.
    • Ensure that the lightbulb is fitted into its housing.
  25. 2004-2006 Scion xB Hatch Handle Replacement: adım 25, 1 resimden 1.
    • Nest the wiring into the channel to the new hatch handle.
    • Ensure the wiring is fitted in place.
  26. 2004-2006 Scion xB Hatch Handle Replacement: adım 26, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 26, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 26, 3 resimden 3.
    • Insert the right light bulb into its housing.
    • Use your pliers to screw the lightbulb clockwise securing it into the new hatch handle.
  27. 2004-2006 Scion xB Hatch Handle Replacement: adım 27, 2 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 27, 2 resimden 2.
    • Nest the right lightbulb wiring into the channel.
  28. 2004-2006 Scion xB Hatch Handle Replacement: adım 28, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 28, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 28, 3 resimden 3.
    • Lineup both of the tabs on the back of the button with square holes on the handle.
    • Push it in until the plastic 'U' shaped tabs are all the way through.
  29. 2004-2006 Scion xB Hatch Handle Replacement: adım 29, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 29, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 29, 3 resimden 3.
    • Refasten the two Phillips screws to secure the handle.
    • The handle assembly is now ready to be reinstalled on the vehicle.
  30. 2004-2006 Scion xB Hatch Handle Replacement: adım 30, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 30, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 30, 3 resimden 3.
    • Thread the wiring through the large hole above the top right corner of the license plate.
    • Seal the wiring by squeezing it and pushing the front half of the rubber grommet through the hole.
  31. 2004-2006 Scion xB Hatch Handle Replacement: adım 31, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 31, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 31, 3 resimden 3.
    • Place the loose wiring below the bolt.
    • Line up the bolts on the handle with the proper holes on the hatch.
    • Push the hatch handle until the bolts are fully through.
  32. 2004-2006 Scion xB Hatch Handle Replacement: adım 32, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 32, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 32, 3 resimden 3.
    • Screw the nut tightly around the bolt coming through from the hatch handle.
    • Tighten the nut with pliers as needed.
  33. 2004-2006 Scion xB Hatch Handle Replacement: adım 33, 2 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 33, 2 resimden 2.
    • Screw the nut tightly around the bolt coming through from hatch handle.
    • Tighten the nut with pliers if needed.
  34. 2004-2006 Scion xB Hatch Handle Replacement: adım 34, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 34, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 34, 3 resimden 3.
    • Line up the white wire cap with the corresponding hole in the hatch.
    • Push and twist counter-clockwise until locked in position.
  35. 2004-2006 Scion xB Hatch Handle Replacement: adım 35, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 35, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 35, 3 resimden 3.
    • Line up the blue wire cap with the corresponding hole in the hatch.
    • Push and twist counter-clockwise until locked in the correct position.
  36. 2004-2006 Scion xB Hatch Handle Replacement: adım 36, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 36, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 36, 3 resimden 3.
    • Reconnect the white cable until you hear a 'CLICK'.
  37. 2004-2006 Scion xB Hatch Handle Replacement: adım 37, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 37, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 37, 3 resimden 3.
    • Reconnect the blue cable until you hear a 'CLICK'.
  38. 2004-2006 Scion xB Hatch Handle Replacement: adım 38, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 38, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 38, 3 resimden 3.
    • Line up the panel holes with the metal holes on the hatch.
    • Push center locking cap into the center hole until you hear a 'CLICK'.
  39. 2004-2006 Scion xB Hatch Handle Replacement: adım 39, 3 resimden 1. 2004-2006 Scion xB Hatch Handle Replacement: adım 39, 3 resimden 2. 2004-2006 Scion xB Hatch Handle Replacement: adım 39, 3 resimden 3.
    • Push the locking cap through the panel hole until you hear a 'CLICK'
    • Repeat for all thirteen locking caps.
Sonuç
Your new hatch handle will be functional and good as new!
Dominic Chan
529 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-7, Morris Winter 2024 UC Davis, Team 1-7, Morris Winter 2024 üyesi
UCD-MORRIS-W24S1G7
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 249
