Ana içeriğe geç
2004 Honda Pilot Timing Belt Replacement
Neye ihtiyacın var
  1. 2004 Honda Pilot Timing Belt Replacement, Timing Belt: adım 1, 1 resimden 1.
    • Looking from above showing the accessory belts removed along with the motor mount.
  2. 2004 Honda Pilot Timing Belt Replacement: adım 2, 1 resimden 1.
    • Side view showing same including the lower cover
  3. 2004 Honda Pilot Timing Belt Replacement: adım 3, 1 resimden 1.
    • Crank pulley bolt removal (loosen the bolt before removing the motor mount!)
  4. 2004 Honda Pilot Timing Belt Replacement: adım 4, 1 resimden 1.
    • Lower cover showing crank end and lower part of the dipstick tube (hydraulic tensioner can be seen behind VTEC solenoid) (crank timing mark can also be seen)
  5. 2004 Honda Pilot Timing Belt Replacement: adım 5, 1 resimden 1.
    • Upper and lower covers removed (12mm power steering adjuster nut shown)
  6. 2004 Honda Pilot Timing Belt Replacement: adım 6, 1 resimden 1.
    • Lower cover removed (rubber plug in the dipstick opening to prevent trash from falling in)
  7. 2004 Honda Pilot Timing Belt Replacement: adım 7, 1 resimden 1.
    • Different angle to show both 14mm pulley bolts
  8. 2004 Honda Pilot Timing Belt Replacement: adım 8, 1 resimden 1.
    • Top view showing timing belt, tensioner, and pulleys off
  9. 2004 Honda Pilot Timing Belt Replacement: adım 9, 1 resimden 1.
    • Top view showing water pump. Also showing the belt, pulleys, and tensioner removed
  10. 2004 Honda Pilot Timing Belt Replacement: adım 10, 1 resimden 1.
    • Bottom view showing the belt, pulleys, and tensioner removed
  11. 2004 Honda Pilot Timing Belt Replacement: adım 11, 1 resimden 1.
    • Bolt (silver one closer to the front of the block) with thread lock
  12. 2004 Honda Pilot Timing Belt Replacement: adım 12, 1 resimden 1.
    • Old parts and removed parts
  13. 2004 Honda Pilot Timing Belt Replacement: adım 13, 1 resimden 1.
    • Old parts, lower cover, motor mount
  14. 2004 Honda Pilot Timing Belt Replacement: adım 14, 1 resimden 1.
    • Covers, mount, dipstick (and new o-ring)
  15. 2004 Honda Pilot Timing Belt Replacement: adım 15, 1 resimden 1.
    • Various tools used (bag shows the part number for the trim clips)
Sonuç
This job is a great example where parts are cheap and labor is expensive. If you are able to do this yourself you can easily save 80% of your bill.
Bir başkası bu kılavuzu tamamladı.
Collin Smith
28 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 19
Her zaman: 3,297
