Ana içeriğe geç
2004 Lexus 330 RX Battery Replacement
Neye ihtiyacın var
  1. 2004 Lexus 330 RX Battery Replacement, Battery: adım 1, 3 resimden 1. 2004 Lexus 330 RX Battery Replacement, Battery: adım 1, 3 resimden 2. 2004 Lexus 330 RX Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Pull up the lever underneath the steering wheel to pop up the hood.
    • Unlatch the hood.
    • The battery should be located on the lower right side of engine.
  2. 2004 Lexus 330 RX Battery Replacement: adım 2, 3 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 2, 3 resimden 2. 2004 Lexus 330 RX Battery Replacement: adım 2, 3 resimden 3.
    • Use a wrench with a 10 mm socket to remove the bolts of the bracket.
    • Repeat the step above for the second bolt.
  3. 2004 Lexus 330 RX Battery Replacement: adım 3, 3 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 3, 3 resimden 2. 2004 Lexus 330 RX Battery Replacement: adım 3, 3 resimden 3.
    • Remove the metal rod on top of the battery.
    • The second and third pictures were taken without the battery for a better view of the rod.
  4. 2004 Lexus 330 RX Battery Replacement: adım 4, 3 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 4, 3 resimden 2. 2004 Lexus 330 RX Battery Replacement: adım 4, 3 resimden 3.
    • Remove the bolts on the clamps with a 10 mm socket.
    • Repeat the process on the second terminal of the battery.
  5. 2004 Lexus 330 RX Battery Replacement: adım 5, 3 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 5, 3 resimden 2. 2004 Lexus 330 RX Battery Replacement: adım 5, 3 resimden 3.
    • Carefully remove the clamps from the terminal.
    • Sometimes clamps are stuck in place due to corrosion or battery leak. Use caution while removing it.
  6. 2004 Lexus 330 RX Battery Replacement: adım 6, 2 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 6, 2 resimden 2.
    • Carefully remove the battery from the engine.
    • Do not tilt the battery while removing it.
  7. 2004 Lexus 330 RX Battery Replacement: adım 7, 2 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 7, 2 resimden 2.
    • Insert the new battery in the engine.
    • Place the metal rod back in place.
  8. 2004 Lexus 330 RX Battery Replacement: adım 8, 2 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 8, 2 resimden 2.
    • Place the bracket back on top of the battery.
    • Use a wrench with a 10 mm socket to secure the bolts of the bracket.
    • Repeat the above step for the second bolt.
  9. 2004 Lexus 330 RX Battery Replacement: adım 9, 3 resimden 1. 2004 Lexus 330 RX Battery Replacement: adım 9, 3 resimden 2. 2004 Lexus 330 RX Battery Replacement: adım 9, 3 resimden 3.
    • Put the terminal back on.
    • Put the bolts on the clamps back on with a 10 mm socket.
    • Repeat the previous step for the second bolt.
Sonuç
You have successfully changed the battery of Lexus 330 RX 200. Good Job!
5 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 87
Her zaman: 3,236
