Giriş
If you are looking to replace the passenger side window for a 2004 Toyota 4Runner use this guide to fix it.
Fixing the window of your car can seem awfully difficult but with this guide, it can be easily done in under an hour. There are several reasons why you might need this guide. If your car window is loose and dislodges whenever you roll it up or down, you can use this guide to put it back in place. If your previous window was shattered and you want to install a new one, this guide is just for you. (If your previous glass was shattered make sure to clean up any glass shards before installing the new glass.)
Before beginning, be sure to turn off the ignition, place the car in park, and engage the parking brake.
Neye ihtiyacın var
Prop the door open.
Using an upholstery remover, remove the plastic cap.
Using a hook tool, remove the plastic panel behind the door handle.
Remove the armrest using a trim panel removal tool.
