Ana içeriğe geç
2004 Toyota 4Runner Passenger Side Window Replacement
Neye ihtiyacın var
  1. 2004 Toyota 4Runner Passenger Side Window Replacement, Passenger Side Window: adım 1, 3 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement, Passenger Side Window: adım 1, 3 resimden 2. 2004 Toyota 4Runner Passenger Side Window Replacement, Passenger Side Window: adım 1, 3 resimden 3.
    • Before starting, make sure the window is fully rolled down.
    • Prop the door open.
    • Using an upholstery remover, remove the plastic cap.
    • Using a hook tool, remove the plastic panel behind the door handle.
    • Remove the armrest using a trim panel removal tool.
  2. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 2, 2 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 2, 2 resimden 2.
    • Remove the two screws from the door panel using a Phillips #0 screwdriver.
  3. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 3, 3 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 3, 3 resimden 2. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 3, 3 resimden 3.
    • Remove the light using an upholstery remover.
    • Disconnect the lights by applying pressure on the clip and pulling outwards.
  4. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 4, 3 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 4, 3 resimden 2. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 4, 3 resimden 3.
    • Lift the door panel carefully off of the door.
    • Use caution as there are still wires attached to it.
    • Disconnect the green and white wires by pulling outward with your fingers.
    • Disconnect the wires by applying pressure to the sides of the white clip and pulling with your fingers.
  5. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 5, 2 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 5, 2 resimden 2.
    • Remove the four screws using a Phillips #0 screwdriver.
    • Disconnect the speaker by pulling out the white wires.
  6. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 6, 2 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 6, 2 resimden 2.
    • Remove the two bolts using the drive ratchet.
    • The steps are the same for replacing a faulty glass and installing a new glass because the last one shattered. If the previous glass shattered just make sure to clean up all the glass shards in the door with a vaccum.
  7. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 7, 2 resimden 1. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 7, 2 resimden 2.
    • Remove the glass carefully by lifting it up with both hands.
  8. 2004 Toyota 4Runner Passenger Side Window Replacement: adım 8, 1 resimden 1.
    • When installing the new glass, make sure it aligns perfectly in the black molding shown in the picture.
Sonuç
Carlos Lopez
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 770
