Giriş
This guide is meant to be used for the 2007 Hummer H3.
Keep in mind that there may be discrepancies if you use this guide for a different model year.
In this guide, there are two wires to disconnect. To prevent injury/harm, it is recommended that the vehicle be switched off, followed by disconnecting the battery.
Neye ihtiyacın var
Use your 10-millimeter wrench to remove the hex nuts on the negative terminal. (Image 1)
Once the negative terminal's hex nut is removed, we can tuck the negative terminal and cable beside the battery. (Image 2)
Repeat these two steps for the positive terminal.
Remove the three highlighted fasteners with the T30 Torx Screwdriver. (Image 1 & 2)
Shimmy the prybar along the outlined area until you feel a slight detachment from the door panel. (Image 1)
Grab the door panel and pull the bottom portion towards yourself slightly. (Image 2)
With the panel pulled slightly towards you, you can lift it, releasing it from the frame. (Image 3)
Locate the two metal cables used for the handle and locking mechanism attached to the ball sockets behind the door panel. (Image 1)
Rotate the yellow cable 90 degrees counterclockwise and lift the cable from the ball socket. Repeat for the green cable. (Image 2)
With both cables removed from the panel, we can now remove the Blue electrical cable.
Press on the clip of the blue cable and gently unplug. (Image 3)
Locate the four fasteners that hold the speaker in place. (Image 1)
Use the Phillips Head Screwdriver size PH2 to remove the four fasteners (Image 2)
With the fasteners removed, we can gently pull the speaker out, which will reveal the final cable.
Locate the clip on the cable connected to the speaker and gently unplug it. (Image 3)
