Giriş
The steps in this guide outline the procedure to replace the brake shoes on all Focus models in the 2005-2007 generation, except for the ST model, which has rear disc brakes. These instructions also can be used to replace the brake drums, in addition to the shoes. Caution should be exercised when working with brake and suspension components, and proper safety goggles should be worn at all times.
Whenever working on your car's brakes and suspension, work on one side at a time. Keep the other side completely assembled so that you can reference it at any time.
Never drive a car if the brakes on one side only are changed, because the car will "pull" to one side.
Neye ihtiyacın var
Jack up the rear of the car and place it on jack stands. Remove the rear wheels and chock the front wheels.
Open the hood and locate the brake fluid reservoir.
Remove the cap from the brake fluid reservoir and set it aside.
Use a turkey baster to remove 2-3 ounces of brake fluid from the reservoir to prevent overflow when working on the brakes.
If you are replacing the brake drums, then follow the appropriate directions for your replacement part: with or without the bearing installed. If you are not replacing the drums, keep in mind that the rear wheel hub bolt that holds the bearing in place must be torqued to 175 ft-lbs.
This sentence: “If you are not replacing the drums, keep in mind that the rear wheel hub bolt that holds the bearing in place must be torqued to 175 ft-lbs.”
Is misleading. It is better written as “If you remove the wheel hub bolt, which holds the bearing, keep in mind it must be reinstalled with torque of 175 ft-lbs.”
This is because if you are not replacing the drum, then you can still remove the four bolts around back.
Use a mallet and a flat head screwdriver to make a small indentation along the edge of the wheel bearing dust cap.
Pry the dust cap out of the brake drum with the flat head screwdriver.
Remove the 29 mm rear hub bolt nut from the brake drum. This will require either a breaker bar or an impact wrench.
Also, some installers swear the nut on some vehicles is 30mm AND that it should not be used more than TWICE. YMMV, but if your car is USED, I’d recommend replacing the nut the first time if you ever do this.
But if possible, it’s better to do the four bolts on the back - at the very least it will save you buying a 29 or 30mm socket.
Use a socket wrench with a swivel adapter to remove the four 13 mm bolts from the back of the hub assembly.
I have tried this method but the break line was in a way. I’ve used swivel adapter with extension but there was no room to turn the wrench, control arm(?) and suspension where in the way.
Are these bolts what come through the spindle hub flange?
Use a flat head screwdriver to remove the two brake shoe retaining clips.
Pull the small retaining pins out from the back side of the hub assembly.
Reassemble the brake shoe assembly with your new brake shoes and hardware.
your spring in the first photo faces the other direction than the same spring in the bottom photo.. which is it.
Place the cap back on the brake fluid reservoir.
Turn the key to the "on" position. Press the brake pedal a few times; it should go to the floor once, and then become firm.
If needed, remove the reservoir cap and add brake fluid until the level is between the "max" and "min" lines.
Close the hood and lower the car back to the ground.
Go for a drive and enjoy your new-found stopping power!
17 farklı kişi bu kılavuzu tamamladı.
10 Yorum
This guide should also tell you if you are installing a new drum to remove the abs sensor ring from the old drum and put it on the new one. I threw my old drum away without knowing that and now my abs light is on.
Very true: I was a given a 2005 Focus with a glowing ABS light and when I pulled the drums to inspect, sure enough: whoever replaced the drums neglected to install the sensor rings.
Here another how to that shows hub removed in case anyone else is as easily confused as me!
Is there any adjustment of the shoes?
If after four king nut removals, would Loc-tite red be adequate? Use Loc-tite blue within the four-time tightening limit?
I'm personally not sure grease is a good idea. Dust, grease/oil and don't mix well; they usually stick, more, shortly after. I don't know if this is accepted now or not. The intent is recognized, but I think the heat should also make it run very shortly.
You can easily sop up fluid from the master cylinder (m/c) with a paper towel; it's usually very little needed.
The instruction may want to add to add fluid to the m/c after pressing the brake pedal and setting the shoes.
I've never heard of drum brakes being "noisey".
Looks similar to 2008 also.
Grease is always part of any brake job. Always has been. As instructed, it will never have any effect on braking performance. Even if some got on the shoe it would largely be irrelevant after a short while as it would be vaporized from the friction.
And the procedure is the same 00 to 11 supposedly. At least for the US/Canada as it’s all the same platform.
Bee Eff -
Adjustment IS required, but was not covered. Given the torque involved, neither red nor blue Loctite is needed. Spindle nut replacement is manufacturer-recommended, though many re-use them indefinitely with no apparent problem: it’s your call. Grease is an excellent idea, and part of any brake job. Personally, I use high-temp synthetic brake grease, though white lithium is probably OK for the relatively lower operating temperature of rear drum brakes vs. front disks. Brakes can certainly develop a noise, given the moving parts in close contact, especially without lubrication.
You have confused and SWAPPED the “removed the wheel bearing with the brake drum” on both the take-apart and install. When you “remove the wheel bearing with” it means the center spindle, nut and cap all STAY in place and you undo and replace the 4 bolts on the back - everything comes off in ONE PIECE. Not the other way around.
This needs to be fixed for this guide to make sense.
