Ana içeriğe geç
2005 Ford Focus ZXW Tail Light Bulb Replacement
Neye ihtiyacın var
  1. 2005 Ford Focus ZXW Tail Light Bulb Replacement, Tail Light Bulb: adım 1, 2 resimden 1. 2005 Ford Focus ZXW Tail Light Bulb Replacement, Tail Light Bulb: adım 1, 2 resimden 2.
    • Open the trunk door.
  2. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 2, 2 resimden 1. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 2, 2 resimden 2.
    • Remove the two screws with the Phillips screwdriver, rotating counter clockwise.
    • The taillight housing can now be detached from the vehicle.
  3. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 3, 3 resimden 1. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 3, 3 resimden 2. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 3, 3 resimden 3.
    • Gently pull the detached taillight housing away from the vehicle.
    • There will be wires attached to two different bulb sockets.
  4. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 4, 2 resimden 1. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 4, 2 resimden 2.
    • Disconnect the harness from the bulb socket by pushing in on the tabs and pulling.
    • Removing the harness from the bulb socket might require some force. Try moving the harness back and forth while pushing on the tabs if you are having trouble removing the harness.
    • Repeat the last two steps to disconnect the second harness from the bulb socket.
  5. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 5, 2 resimden 1. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 5, 2 resimden 2.
    • Remove the damaged bulb by firmly gripping the bulb and pulling.
    • Removing the bulb from the socket may require some force.
    • Be careful while handling the bulb as it may break.
  6. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 6, 2 resimden 1. 2005 Ford Focus ZXW Tail Light Bulb Replacement: adım 6, 2 resimden 2.
    • Place the new bulb in the bulb socket.
    • Repeat this process to replace the second bulb.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Megn Thomason
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 68
Her zaman: 1,296
