Ana içeriğe geç
2005 Honda CR-V Car Visor Replacement
Neye ihtiyacın var
  1. 2005 Honda CR-V Car Visor Replacement, Car Visor: adım 1, 2 resimden 1. 2005 Honda CR-V Car Visor Replacement, Car Visor: adım 1, 2 resimden 2.
    • Ensure that the car is parked and utilize the parking brake.
    • Press the switch on the left of the parking lever, pull it outwards, and release it when it is fixed and outward.
  2. 2005 Honda CR-V Car Visor Replacement: adım 2, 2 resimden 1. 2005 Honda CR-V Car Visor Replacement: adım 2, 2 resimden 2.
    • Remove the outer shell with a spudger.
    • When the outer shell is loose enough, remove it with your hand.
  3. 2005 Honda CR-V Car Visor Replacement: adım 3, 3 resimden 1. 2005 Honda CR-V Car Visor Replacement: adım 3, 3 resimden 2. 2005 Honda CR-V Car Visor Replacement: adım 3, 3 resimden 3.
    • Remove the two 4.5 mm screws from the visor with a Torx screwdriver.
    • After removing the inner layer, the sun visor is now released.
  4. 2005 Honda CR-V Car Visor Replacement: adım 4, 2 resimden 1. 2005 Honda CR-V Car Visor Replacement: adım 4, 2 resimden 2.
    • Put the 4.5 mm screw removed in the previous step in the new sun visor.
    • Tighten the screw using a Torx screwdriver.
    • Also, note that the shape of the shell is aligned with the form of the hole in the roof.
  5. 2005 Honda CR-V Car Visor Replacement: adım 5, 2 resimden 1. 2005 Honda CR-V Car Visor Replacement: adım 5, 2 resimden 2.
    • Screw in the rest of the 4.5 mm screws back in the sun visor using a Torx screwdriver.
    • Ensure that the screws are tight.
  6. 2005 Honda CR-V Car Visor Replacement: adım 6, 3 resimden 1. 2005 Honda CR-V Car Visor Replacement: adım 6, 3 resimden 2. 2005 Honda CR-V Car Visor Replacement: adım 6, 3 resimden 3.
    • Put the outer shell back on top of the inner shell.
    • Finally, ensure that the sun visor can be moved to the driver-side window and twisted upwards and downwards.
Sonuç
To replace the new sun visor with the old sun visor, follow these steps in the same order.
An Chen
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 39
Her zaman: 786
