Ana içeriğe geç
2005 Honda S2000 Valve Cover Gasket Replacement
Neye ihtiyacın var
  1. 2005 Honda S2000 Valve Cover Gasket Replacement, Valve Cover Gasket: adım 1, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement, Valve Cover Gasket: adım 1, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement, Valve Cover Gasket: adım 1, 3 resimden 3.
    • Using a 3/8" drive ratchet, remove the four screws that hold on the spark plug cover.
  2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 2, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 2, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 2, 3 resimden 3.
    • Unplug both plugs on the back of the valve cover.
    • Undo the clip holding the wire harness.
  3. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 3, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 3, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 3, 3 resimden 3.
    • Using a 10mm deep socket and a Torque wrench, remove the four 10mm bolts from all four coil packs.
  4. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 4, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 4, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 4, 3 resimden 3.
    • Only unplug the last coil pack. Then pull all the coil packs out of the spark plug holes.
  5. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 5, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 5, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 5, 3 resimden 3.
    • Move connected coil packs over to make free space.
  6. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 6, 2 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 6, 2 resimden 2.
    • Loosen the clamps on both vacuum lines. Slide both lines off. Remove the oil dipstick and oil cap.
  7. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 7, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 7, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 7, 3 resimden 3.
    • Use both hands and slowly and evenly pull up on the valve cover.
    • Clean any oil residue from the surface where the valve cover sits.
  8. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 8, 2 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 8, 2 resimden 2.
    • Compare the old and new parts and make sure they are the same. Clean the inside of the valve cover with an old rag.
  9. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 9, 2 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 9, 2 resimden 2.
    • Apply a small amount of force on both sides of the cover. Gently wiggle it on and ensure nothing gets caught on it.
  10. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 10, 3 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 10, 3 resimden 2. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 10, 3 resimden 3.
    • Put both vacuum lines back on and tighten them down with the clamps.
    • Put on the new washers that hold down the cover; these easily pop on.
  11. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 11, 2 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 11, 2 resimden 2.
    • Place the 4 coils back into the spark plug holes and tighten the bolts. Plug in the last coil pack.
    • Plug in the last coil pack.
    • Tighten the five bolts that hold down the valve cover.
  12. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 12, 2 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 12, 2 resimden 2.
    • Plug the two plugs back in on the back of the valve cover.
  13. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 13, 2 resimden 1. 2005 Honda S2000 Valve Cover Gasket Replacement: adım 13, 2 resimden 2.
    • Tighten the spark plug cover with its 4 bolts.
    • Reattach the oil cap and oil dipstick.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 32
Her zaman: 2,447
