Ana içeriğe geç
2005 Mustang GT Serpentine Belt Tensioner Replacement
Neye ihtiyacın var
  1. 2005 Mustang GT Serpentine Belt Tensioner Replacement, Serpentine Belt Tensioner: adım 1, 1 resimden 1.
    • To open the hood, pull the hood latch located on the left side of the driver's foot well.
  2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 2, 3 resimden 1. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 2, 3 resimden 2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 2, 3 resimden 3.
    • Push a lever (located just above the horse in the grill) to the left.
    • Lift the hood up, pull the prop out, and insert it into the hole on the hood labeled "prop."
  3. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 3, 2 resimden 1. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 3, 2 resimden 2.
    • Disconnect the battery using an 8 mm socket and 3/8 inch drive ratchet.
  4. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 4, 1 resimden 1.
    • Loosen the band clamp on the throttle body with a flathead screwdriver.
  5. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 5, 1 resimden 1.
    • Loosen the band clamp on the air filter or airbox.
  6. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 6, 3 resimden 1. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 6, 3 resimden 2. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 6, 3 resimden 3.
    • Pull the intake tube back and to the left to remove it from the throttle body and airbox.
    • Place the intake tube out of the way
  7. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 7, 1 resimden 1.
    • Make note of the orientation that the serpentine belt runs. If the tensioner is broken, and the belt is no longer on, refer to a diagram for the vehicle. If still attached, release tension on the belt using a 1/2 inch breaker bar turned in the clockwise direction and remove it.
  8. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 8, 1 resimden 1.
    • Remove the three 10 mm bolts with your 3/8 drive and 10 mm socket.
    • Remove the tensioner.
  9. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 9, 1 resimden 1.
    • Install the new tensioner and torque the bolts to 20ft lbs. then using the breaker bar turn clockwise to allow the reinstallation of the belt.
    • Using the breaker bar, turn clockwise to allow the reinstallation of the belt.
  10. 2005 Mustang GT Serpentine Belt Tensioner Replacement: adım 10, 1 resimden 1.
    • Make sure all the grooves of the pullies are seated in the belt correctly, then release the tensioner to seat the belt.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Hall
202 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 2,833
