Ana içeriğe geç
2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement
Neye ihtiyacın var
  1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement, Liftgate Latch/Back Lock Sub-Assembly: adım 1, 2 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement, Liftgate Latch/Back Lock Sub-Assembly: adım 1, 2 resimden 2.
    • Open the trunk door if you are able to do so.
    • Opening the trunk door will allow you to more easily remove the trim and access other components.
    • If you cannot open the trunk, ignore this step. The guide will show you later on how to open a stuck truck door.
  2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 2, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 2, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 2, 3 resimden 3.
    • Pull upwards on the plastic covering the trunk strap to remove it.
  3. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 3, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 3, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 3, 3 resimden 3.
    • Using a Phillips screwdriver, remove the screw holding the trunk strap.
  4. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 4, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 4, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 4, 3 resimden 3.
    • Use a plastic trim kit to start removing the trim on the trunk door.
    • You may have to use your hands and pull if you have difficulties removing the trim.
  5. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 5, 2 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 5, 2 resimden 2.
    • Use a 10 mm socket wrench or ratchet and remove the 8 screws located on the edge of the metal trunk cover.
    • Don't worry about the metal trunk cover falling off; there are plastic discs holding it in place.
  6. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 6, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 6, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 6, 3 resimden 3.
    • Use a spudger to partially pry open the plastic discs holding the metal trunk cover and push the trunk cover off the discs.
  7. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 7, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 7, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 7, 3 resimden 3.
    • Use a flashlight to follow the black cable that leads to a plastic covering which hides door latch cable.
    • Use your fingers to pull down on the plastic covering and remove it.
  8. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 8, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 8, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 8, 3 resimden 3.
    • Use your hand to pull the cable downwards to release the bottom half of the cable.
    • Push the cable towards the metal ball and push downwards to release the cable fully.
  9. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 9, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 9, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 9, 3 resimden 3.
    • Use a spudger to pry open the plastic holder and take the cable halfway out.
    • If you were unable to open the trunk door on the first step, you can now open it by pulling the metal ball on the black cable. This will open the trunk.
  10. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 10, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 10, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 10, 3 resimden 3.
    • Use a spudger to pry off the plastic covering the trunk latch.
    • Use a 10mm socket wrench or ratchet to remove the three screws.
    • Push upwards and in on the trunk latch.
  11. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 11, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 11, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 11, 3 resimden 3.
    • Using your fingers or a spudger, squeeze both sides and push in.
  12. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 12, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 12, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 12, 3 resimden 3.
    • Use a flashlight and your hands to squeeze to remove white plastic plug connected to the trunk latch.
  13. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 13, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 13, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 13, 3 resimden 3.
    • Using your hands, slide the trunk latch to the right side of the trunk and remove.
  14. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 14, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 14, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 14, 3 resimden 3.
    • Use a spudger or your hands to squeeze and remove the black plug.
  15. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 15, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 15, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 15, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two screws holding the plastic trunk latch cover.
  16. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 16, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 16, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 16, 3 resimden 3.
    • Use your hands to pull downwards on the black cable to expose more of the trunk latch from the plastic covering.
    • Remove the plastic covering by pulling it clockwise from the trunk latch.
  17. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 17, 3 resimden 1. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 17, 3 resimden 2. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 17, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two screws holding the actuator motor to the trunk latch.
  18. 2005 Toyota Sequoia 2005 Liftgate Latch/Back Lock Sub-Assembly Replacement: adım 18, 1 resimden 1.
    • You can now reuse or replace your old actuator motor and attach it to a new liftgate latch.
Sonuç
Evan Jimenez
277 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 2,886
