Ana içeriğe geç
2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement
Neye ihtiyacın var
  1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: adım 1, 3 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: adım 1, 3 resimden 2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: adım 1, 3 resimden 3.
    • Pull the hood release in the lower left of the driver's side of your car.
    • Lift the hood of your car until it stays up on its own.
  2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 2, 2 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 2, 2 resimden 2.
    • Use any size flathead screwdriver to remove the screw plugs that are holding down the engine cover.
  3. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 3, 3 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 3, 3 resimden 2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 3, 3 resimden 3.
    • Remove the bottom engine cover.
  4. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 4, 2 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 4, 2 resimden 2.
    • Use a 1/4" flathead screwdriver to remove the screw holding down the top engine cover.
  5. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 5, 3 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 5, 3 resimden 2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 5, 3 resimden 3.
    • Remove the side engine cover.
  6. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 6, 3 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 6, 3 resimden 2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 6, 3 resimden 3.
    • Use a 10 mm wrench to remove the washer fluid tube.
  7. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 7, 2 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 7, 2 resimden 2.
    • Locate the headlight bulb's cover.
  8. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 8, 2 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 8, 2 resimden 2.
    • Push the metal bar down to release the cover.
  9. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 9, 2 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 9, 2 resimden 2.
    • Remove the bulb cover.
  10. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 10, 3 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 10, 3 resimden 2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 10, 3 resimden 3.
    • Twist the headlight bulb cap counterclockwise (1/4 turn) to detach.
  11. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 11, 3 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 11, 3 resimden 2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 11, 3 resimden 3.
    • Push the metal clips inward to release the headlight bulb.
    • Pull the bull out of the socket.
  12. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 12, 2 resimden 1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: adım 12, 2 resimden 2.
    • Insert the new headlight bulb.
    • Make sure not to touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Use gloves to avoid oil and salt transfer to the bulb.
Sonuç
Daniel R
205 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 66
Son 30 gün: 278
Her zaman: 918
