Ana içeriğe geç
2006-2013 Toyota Corolla Brake Light Replacement
Neye ihtiyacın var
  1. 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: adım 1, 3 resimden 1. 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: adım 1, 3 resimden 2. 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: adım 1, 3 resimden 3.
    • Open the trunk of the vehicle.
    • Locate the taillight area that needs fixing either on the right and/or left.
    • We are fixing the left side in this guide.
  2. 2006-2013 Toyota Corolla Brake Light Replacement: adım 2, 1 resimden 1.
    • Using a flathead screwdriver, pry the 3 fasteners out.
  3. 2006-2013 Toyota Corolla Brake Light Replacement: adım 3, 2 resimden 1. 2006-2013 Toyota Corolla Brake Light Replacement: adım 3, 2 resimden 2.
    • Pull back the covering to reveal the taillight area.
    • Locate the brake light bulb in the brown socket at the inner end of the taillight area.
  4. 2006-2013 Toyota Corolla Brake Light Replacement: adım 4, 2 resimden 1. 2006-2013 Toyota Corolla Brake Light Replacement: adım 4, 2 resimden 2.
    • Rotate the brown socket counterclockwise and pull out the socket.
    • Pull the nonfunctioning light bulb from its socket and replace with the new, functioning bulb
    • Put the brown socket back in place and rotate clockwise to secure it
    • Put the covering back in place and secure the 3 fasteners. No tools are required, simply push the fasteners into position.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I had to use pliers carefully to turn the brown socket, but this worked perfectly. Thank you!
Josh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 81
Son 30 gün: 350
Her zaman: 8,801
