Ana içeriğe geç
2006-2011 Honda Civic Key FOB Battery Replacement
  1. 2006-2011 Honda Civic Key FOB Battery Replacement, Key FOB Battery: adım 1, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
  2. 2006-2011 Honda Civic Key FOB Battery Replacement: adım 2, 1 resimden 1.
    • Gently lift the outer shell and remove it from the rest of the device.
    • Be careful not to break the clip located at the hole for the key ring that holds the shell in place.
  3. 2006-2011 Honda Civic Key FOB Battery Replacement: adım 3, 1 resimden 1.
    • Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
  4. 2006-2011 Honda Civic Key FOB Battery Replacement: adım 4, 1 resimden 1.
    • Unclasp the inner shell using the clips on the top and bottom.
    • Careful as to not break the clips as it keeps moisture, dust, and dirt from entering the delicate electronics.
  5. 2006-2011 Honda Civic Key FOB Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery inside of the inner shell of the key FOB.
    • If the battery is corroded, make sure to wear gloves due to battery acid.
    • Do not puncture the battery when removing the old one/placing a new one.
  6. 2006-2011 Honda Civic Key FOB Battery Replacement: adım 6, 1 resimden 1.
    • Replace the old battery with a new one.
Sonuç
To reassemble your key FOB, follow these instructions in reverse order.
Erika Caushi
142 İtibar
1 Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 72
Son 7 gün: 397
Son 30 gün: 2,130
Her zaman: 32,498
