Ana içeriğe geç
2006-2008 Isuzu i-Series Wiper Motor Replacement
Neye ihtiyacın var
  1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nut Caps: adım 1, 1 resimden 1.
    • Use a plastic prying tool or spudger to gently remove nut cap from wiper base.
  2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: adım 2, 3 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: adım 2, 3 resimden 2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Nuts: adım 2, 3 resimden 3.
    • Use a 5/8 wrench or socket to remove the necessary nut holding the wiper in place.
  3. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: adım 3, 2 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Arms: adım 3, 2 resimden 2.
    • Once the necessary nuts are removed, the wiper blade itself can be removed.
    • This can be done easiest by first flexing the wiper to the upright position, then gently pulling the wiper off of the screw.
  4. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: adım 4, 2 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Retainer Clips: adım 4, 2 resimden 2.
    • Open the hood of the truck for easier access to the wiper cowl.
    • Using pliers, locate the six retainer clips on the plastic cowl and remove them by pulling straight up.
  5. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: adım 5, 3 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: adım 5, 3 resimden 2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing Wiper Cowl: adım 5, 3 resimden 3.
    • Position your hands underneath the wiper cowl and start to gently loosen the plastic from the windshield.
    • Pull straight towards the front of the truck to slide the wiper cowl over the screws that held the wiper blades, exposing the wiper components underneath.
    • The wiper cowl is flexible and can therefore be removed a little bit at a time. Take your time.
  6. 2006-2008 Isuzu i-Series Wiper Motor Replacement: adım 6, 3 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement: adım 6, 3 resimden 2. 2006-2008 Isuzu i-Series Wiper Motor Replacement: adım 6, 3 resimden 3.
    • Locate the two screws on each side of the wiper assembly.
    • Use a 10mm socket or wrench and remove each screw.
  7. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: adım 7, 3 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: adım 7, 3 resimden 2. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Removing wiper assembly: adım 7, 3 resimden 3.
    • Rotate assembly towards the windshield while starting to remove it from the truck.
    • Unplug the wiring harness located towards the driver's side of the truck.
    • The wire can then be fed through to remove the assembly the rest of the way.
  8. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: adım 8, 2 resimden 1. 2006-2008 Isuzu i-Series Wiper Motor Replacement, Accessing the Assembly: adım 8, 2 resimden 2.
    • Remove the connecting arm socket with a 1/2 inch wrench or socket (red circle).
    • Remove the three motor bolts with a 10mm wrench or socket (orange circles).
    • The wiper motor is now able to be replaced.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alex
211 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-9, Donnelly Fall 2014 USF Tampa, Team 1-9, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G9
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 3,956
