Ana içeriğe geç
2006 Dodge RAM Turn Signal Bulb Replacement
Neye ihtiyacın var
  1. 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: adım 1, 3 resimden 1. 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: adım 1, 3 resimden 2. 2006 Dodge RAM Turn Signal Bulb Replacement, Turn Signal Bulb: adım 1, 3 resimden 3.
    • Remove the two screws securing the light to the truck using an Allen wrench.
  2. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 2, 3 resimden 1. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 2, 3 resimden 2. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 2, 3 resimden 3.
    • Pull the light casing out of the socket.
    • The wires exposed at the back of the light case are dangerous to touch as they are exposed electrical wires. Do not interact with them.
  3. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 3, 3 resimden 1. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 3, 3 resimden 2. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 3, 3 resimden 3.
    • Remove the four screws from the light case.
  4. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 4, 3 resimden 1. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 4, 3 resimden 2. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 4, 3 resimden 3.
    • Remove the light case from the light bulb holders.
  5. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 5, 3 resimden 1. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 5, 3 resimden 2. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 5, 3 resimden 3.
    • Replace the light bulb by gently pulling the original light bulb out.
    • Replace the lightbulb with a new one.
  6. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 6, 3 resimden 1. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 6, 3 resimden 2. 2006 Dodge RAM Turn Signal Bulb Replacement: adım 6, 3 resimden 3.
    • Reattach the lightbulbs to the light casing and put the 4 screws back in.
    • Pop the light casing back into place by making sure the two pointed ends go into the holes.
    • Replace the two screws that secure the light to the truck using an Allen wrench.
Bitiş Çizgisi
Eddie Echegoyen
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 235
