Ana içeriğe geç
2006 Honda Shadow Spirit 750 Battery Replacement
Neye ihtiyacın var
  1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: adım 1, 1 resimden 1.
    • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
  2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: adım 2, 3 resimden 1. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: adım 2, 3 resimden 2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: adım 2, 3 resimden 3.
    • The tool box is located under the panel.
    • Using the key to the motorbike, unlock the tool box.
    • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
  3. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: adım 3, 2 resimden 1. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: adım 3, 2 resimden 2.
    • Using the allen wrench, remove the screws on both sides of the bike seat.
  4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: adım 4, 1 resimden 1.
    • Pull the rear of the seat upwards.
    • Pull the seat backwards to remove it from the bike.
  5. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: adım 5, 1 resimden 1.
    • Using the screwdriver, remove the screw holding the plastic cover.
  6. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: adım 6, 1 resimden 1.
    • Pull the cover off the battery and remove the fuse box from the cover.
    • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
  7. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: adım 7, 1 resimden 1.
    • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
    • Place the wire over the left side of the bike.
  8. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: adım 8, 1 resimden 1.
    • Also using the screwdriver, remove the positive (+) cable from the battery.
    • Place the wire over the right side of the bike.
    • Do not let the red(+) and black(-) wires touch
  9. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: adım 9, 1 resimden 1.
    • Remove the battery from the bike by pulling upwards.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Dazarene Cascio
784 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Donnelly Fall 2014 USF Tampa, Team 1-7, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G7
1 Üye
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 211
Her zaman: 19,670
