Ana içeriğe geç
2006 Iron Horse Warrior Rear Wheel Replacement
  1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: adım 1, 2 resimden 1. 2006 Iron Horse Warrior Rear Wheel Replacement, Rear Wheel: adım 1, 2 resimden 2.
    • Turn the bike upside down if you don't have a bike stand. This will make it easier to remove the tire.
    • Unfasten the left side of the wheel by pulling the black "L" shaped lever up with your hands.
  2. 2006 Iron Horse Warrior Rear Wheel Replacement: adım 2, 2 resimden 1. 2006 Iron Horse Warrior Rear Wheel Replacement: adım 2, 2 resimden 2.
    • On the right side, use your hands to unscrew the cap of the axle counterclockwise until it is loose.
  3. 2006 Iron Horse Warrior Rear Wheel Replacement: adım 3, 2 resimden 1. 2006 Iron Horse Warrior Rear Wheel Replacement: adım 3, 2 resimden 2.
    • Push down on the the tire with your hands to remove it from the frame of the bike.
    • Sometimes the axle will get caught in the boxed area. Use both of your hands to cautiously push it down harder until the tire comes loose. This may require a fair amount of force.
Sonuç
Matt Halvorson
354 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 999
