Ana içeriğe geç
2006 Kia Rio Engine Valve Cover Gasket Replacement
Neye ihtiyacın var
  1. 2006 Kia Rio Engine Valve Cover Gasket Replacement, Valve Cover Gasket: adım 1, 1 resimden 1.
    • Open the car's hood using the latch under the steering wheel, next to the door.
  2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 2, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 2, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 2, 3 resimden 3.
    • Remove the battery connection.
    • Loosen the tension bolt on the negative (-) terminal.
    • The stock terminal uses a 10mm bolt.
    • Pull the terminal off the battery and tuck it away.
  3. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 3, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 3, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 3, 3 resimden 3.
    • Remove the four bolts with a 10 mm socket.
    • Take off the dust cover.
  4. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 4, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 4, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 4, 3 resimden 3.
    • Remove the air filter housing.
    • Disconnect the electronics and air intake hoses.
    • Loosen the tension screw on the air intake hose with a 10 mm socket.
    • Undo all latches and pull away the housing cap.
  5. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 5, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 5, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 5, 3 resimden 3.
    • Disconnect the computer terminals.
    • Release the tension clamps on the two terminals.
    • Tuck both terminals out of the way.
  6. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 6, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 6, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 6, 3 resimden 3.
    • Unbolt the air filter housing.
    • Loosen the three 10 mm bolts holding the housing in place.
    • Each photo shows one of the three bolts.
  7. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 7, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 7, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 7, 3 resimden 3.
    • Remove the air intake assembly.
    • Remove both the air filter cap and the housing.
    • Avoid getting the air filter dirty.
  8. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 8, 1 resimden 1.
    • Remove the two 10 mm bolts.
    • Remove the dust cover brackets.
    • Remember the orientation of the removed bracket.
  9. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 9, 2 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 9, 2 resimden 2.
    • There are two hoses connected to the valve cover.
    • Use any set of pliers to loosen the tension clamps on each hose.
    • Disconnect the hoses by pulling them off their contact points.
  10. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 10, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 10, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 10, 3 resimden 3.
    • Remove the air intake pipe.
    • Loosen the 10 mm tension screw to release the clamp on this end of the hose.
    • Pull the hose free from the rear intake assembly.
  11. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 11, 1 resimden 1.
    • Loosen the three 10 mm bolts holding the wire guide in place.
    • Move the guide out of the way.
  12. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 12, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 12, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 12, 3 resimden 3.
    • Remove the two 12 mm bolts from the rear wire bracket.
    • They may be a little hard to find. Look behind and beside the valve cover.
    • Move the rear wire bracket to the side.
  13. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 13, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 13, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 13, 3 resimden 3.
    • Disconnect and remove the ignition coils.
    • Remove the four 10 mm bolts holding the four ignition coils in place.
    • Try to keep the coils connected and in order.
  14. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 14, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 14, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 14, 3 resimden 3.
    • Remove twelve 10 mm bolts from the valve cover on the engine head.
    • Move parts around until each bolt is reachable.
  15. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 15, 2 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 15, 2 resimden 2.
    • Remove the engine head.
    • Make sure the engine is kept clean. Avoid getting dust or other contaminants into the uncovered assembly.
  16. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 16, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 16, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 16, 3 resimden 3.
    • Clean the residue off of the engine block.
    • Keep the rim as clean and level as possible.
    • Apply a steady line of gasket maker with a 1/4" thickness around the engine block.
    • Surround each bolt hole on the block with gasket maker.
  17. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 17, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 17, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 17, 3 resimden 3.
    • Insert the engine block seal into the engine head.
    • If you don't have a valve cover gasket, then you can skip this step.
  18. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 18, 3 resimden 1. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 18, 3 resimden 2. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 18, 3 resimden 3.
    • Place the engine head back on the engine.
    • Potential for device damage: Be careful NOT to get any gasket maker on the exposed assembly.
  19. 2006 Kia Rio Engine Valve Cover Gasket Replacement: adım 19, 1 resimden 1.
    • Re-bolt the engine head cover by hand.
    • Let the seal set for one hour.
    • Tighten the head cover bolts fully after the seal sets.
Sonuç
To reassemble your device, follow these instructions in reverse order. Avoid running the engine for 12 hours to allow the seal to harden.
Bir Yorum
Foi bom ler um ler um sobre desmontagem, por aprende-se a conhecer os nomes técnicos
Oliveira - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 25
Son 30 gün: 113
Her zaman: 3,482
