Ana içeriğe geç
2006 Kia Spectra Battery Replacement
Neye ihtiyacın var
  1. 2006 Kia Spectra Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the car off.
  2. 2006 Kia Spectra Battery Replacement: adım 2, 2 resimden 1. 2006 Kia Spectra Battery Replacement: adım 2, 2 resimden 2.
    • Locate the hood release lever near the lower left side of the steering wheel. Pop the hood by lifting up on the release lever.
  3. 2006 Kia Spectra Battery Replacement: adım 3, 3 resimden 1. 2006 Kia Spectra Battery Replacement: adım 3, 3 resimden 2. 2006 Kia Spectra Battery Replacement: adım 3, 3 resimden 3.
    • Remove the positive (red circle) cable from the battery using the wrench to loosen the nut and bolt.
    • Then, remove the negative (orange circle) cable battery, using the wrench to loosen the nut and bolt.
  4. 2006 Kia Spectra Battery Replacement: adım 4, 2 resimden 1. 2006 Kia Spectra Battery Replacement: adım 4, 2 resimden 2.
    • Take the battery out, lifting the battery.
    • The battery will be heavy.
  5. 2006 Kia Spectra Battery Replacement: adım 5, 1 resimden 1.
    • Clean the new battery with a rag to make sure it is ready to go.
  6. 2006 Kia Spectra Battery Replacement: adım 6, 3 resimden 1. 2006 Kia Spectra Battery Replacement: adım 6, 3 resimden 2. 2006 Kia Spectra Battery Replacement: adım 6, 3 resimden 3.
    • Place the new battery in the base where the battery goes.
  7. 2006 Kia Spectra Battery Replacement: adım 7, 2 resimden 1. 2006 Kia Spectra Battery Replacement: adım 7, 2 resimden 2.
    • Attach the positive (red cirlce) cable to the battery by screwing on the nut and bolt with the wrench.
  8. 2006 Kia Spectra Battery Replacement: adım 8, 3 resimden 1. 2006 Kia Spectra Battery Replacement: adım 8, 3 resimden 2. 2006 Kia Spectra Battery Replacement: adım 8, 3 resimden 3.
    • Then, attach the negative (red arrow) cable to the battery by screwing on the nut and bolt with the wench.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 48
Her zaman: 4,843
