Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the hood release lever near the lower left side of the steering wheel. Pop the hood by lifting up on the release lever.
Remove the positive (red circle) cable from the battery using the wrench to loosen the nut and bolt.
Then, remove the negative (orange circle) cable battery, using the wrench to loosen the nut and bolt.
Clean the new battery with a rag to make sure it is ready to go.
Place the new battery in the base where the battery goes.
Attach the positive (red cirlce) cable to the battery by screwing on the nut and bolt with the wrench.
Then, attach the negative (red arrow) cable to the battery by screwing on the nut and bolt with the wench.
2 farklı kişi bu kılavuzu tamamladı.
