Giriş
Side door mirrors are one of the biggest safety factors when operating a vehicle, given this information it is always important to take care of your mirrors! The mirrors can easily be damaged but just as easily the damage can happen so can the repair. This repair is needed because without a side mirror it is illegal to drive! And instead of taking your vehicle to a dealership and waiting days for a simple repair you can do it in the comfort of your own drive way in under 30 minutes!
Completing this process takes little to no experience with any vehicle. There are no special requirements to be able to do this task, following this guide step by step is all that you need! Hazard wise is also very minimal, dealing with tools you must always be cautious to make sure nothing bad may occur. No matter how experienced one may be, approach this task with caution to make sure damage is not done to the vehicle and to oneself.
With the repair you will need one flat head screw driver and on 10mm wrench, a long with your side mirror replacement.
Once the repair is finished be sure that your mirror is stiff in its place and can still be adjusted for safe driving!
Neye ihtiyacın var
Remove the plastic piece covering from the mirror bolts.
Place the flat head screwdriver behind the plastic covering for leverage.
Pop off the plastic piece to uncover all the hidden bolts.
