Ana içeriğe geç
2007-2014 GMC Sierra Master Power Window Switch Replacement
Neye ihtiyacın var
  1. 2007-2014 GMC Sierra Master Power Window Switch Replacement, Window switch panels of all 07-13' Chevy/GMC Trucks & SUV's: adım 1, 2 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement, Window switch panels of all 07-13' Chevy/GMC Trucks & SUV's: adım 1, 2 resimden 2.
    • Using a flat-head screwdriver, wedge underneath the plastic cover to release it from the assembly.
  2. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 2, 3 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 2, 3 resimden 2. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 2, 3 resimden 3.
    • Unfasten the 10 mm bolts located at the top and bottom of the door assembly.
    • Remove the door assembly.
  3. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 3, 3 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 3, 3 resimden 2. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 3, 3 resimden 3.
    • Wedge the flat-head screwdriver underneath the plastic cover to the switch panel to release it from the door.
  4. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 4, 1 resimden 1.
    • Remove all wire harnesses to the window switches from the back of the panel.
  5. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 5, 2 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 5, 2 resimden 2.
    • With the flat-head screwdriver release the tabs to release the window switch panel from the block of switches.
  6. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 6, 1 resimden 1.
    • Insert new master window switch.
  7. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 7, 2 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 7, 2 resimden 2.
    • Re-plug wire harnesses into the new window switch panel and push panel into the cover.
  8. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 8, 1 resimden 1.
    • Push the re-assembled switch panel down until you hear a click, this means it is secure in the door.
  9. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 9, 3 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 9, 3 resimden 2. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 9, 3 resimden 3.
    • Re-assemble the door arm.
    • Re-fasten the 10 mm bolts to the top and bottom of the door assembly.
  10. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 10, 2 resimden 1. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 10, 2 resimden 2.
    • Re-attach the plastic cover by snapping it into place, start at the bottom for easier installation.
  11. 2007-2014 GMC Sierra Master Power Window Switch Replacement: adım 11, 1 resimden 1.
    • You've completed the fix! Now enjoy your working Master Power Window Switch!
Sonuç
If you continue to have problems with the windows not working properly then it is an issue with either your wiring or motors and should be looked at by a certified technician. Thank you, and I hope my guide helped solve your problem!
2 farklı kişi bu kılavuzu tamamladı.
Kody Benedict
263 İtibar
1 Kılavuz yazıldı
2 Yorum
I have a 2009 Chevy Silverado. i changed the same panel and everything works except drivers window. any thoughts on how to fix it?
Rick Bonetti - Yanıt
I have the same issue with my 2009 GMC Acadia. Does yours click? If so I found a useful how to guide I'm going to try next on this forum
How to Fix a Loose Car Window
Heather Grew -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 129
Her zaman: 5,262
