Ana içeriğe geç
2007-2012 Acura RDX Engine Air Filter Replacement
Neye ihtiyacın var
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: adım 1, 1 resimden 1.
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: adım 2, 1 resimden 1.
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: adım 3, 1 resimden 1.
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: adım 4, 1 resimden 1.
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: adım 5, 2 resimden 1. 2007-2012 Acura RDX Engine Air Filter Replacement: adım 5, 2 resimden 2.
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
Sonuç
One the task is done, close the hood and you are good to drive!
Bir başkası bu kılavuzu tamamladı.
Andrew Graham
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 53
Her zaman: 1,483
