Ana içeriğe geç
2007-2012 Jeep Wrangler Headlight Replacement
Neye ihtiyacın var
  1. 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: adım 1, 2 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement, Headlight: adım 1, 2 resimden 2.
    • Locate the two gray latches on either side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Headlight Replacement: adım 2, 2 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 2, 2 resimden 2.
    • Reach under the hood and push the lever left to right. You should now be able to lift the hood.
    • Prop open the hood by inserting the support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Headlight Replacement: adım 3, 3 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 3, 3 resimden 2. 2007-2012 Jeep Wrangler Headlight Replacement: adım 3, 3 resimden 3.
    • Locate all six push on fasteners on the top of the grill.
    • Use a flathead screwdriver to pry up the fasteners, and make sure you put the screws somewhere safe.
    • If the fasteners will not come up, use two flathead screwdrivers on either side of the fastener to remove.
  4. 2007-2012 Jeep Wrangler Headlight Replacement: adım 4, 3 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 4, 3 resimden 2. 2007-2012 Jeep Wrangler Headlight Replacement: adım 4, 3 resimden 3.
    • Locate right and left blinker lights under the fenders.
    • Twist blinker light toward the ground, and make sure you pull the bulb out carefully.
    • Make sure you are handling bulb carefully.
  5. 2007-2012 Jeep Wrangler Headlight Replacement: adım 5, 3 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 5, 3 resimden 2. 2007-2012 Jeep Wrangler Headlight Replacement: adım 5, 3 resimden 3.
    • Make sure all fasteners are removed from top of the grill, and the top of the grill is loose.
    • Firmly pull the bottom of the grill until the grill disconnects from the jeep.
  6. 2007-2012 Jeep Wrangler Headlight Replacement: adım 6, 2 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 6, 2 resimden 2.
    • Locate the 4 screws holding the headlight in place.
    • Use a star bit screwdriver to unscrew the .164-18 x .625 mm star bit screws around the headlight, and make sure you place screws somewhere safe.
    • Hold the headlight when unscrewing last screw to prevent the headlight from falling.
  7. 2007-2012 Jeep Wrangler Headlight Replacement: adım 7, 2 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 7, 2 resimden 2.
    • Use your hands to carefully remove silver ring from the headlight.
  8. 2007-2012 Jeep Wrangler Headlight Replacement: adım 8, 3 resimden 1. 2007-2012 Jeep Wrangler Headlight Replacement: adım 8, 3 resimden 2. 2007-2012 Jeep Wrangler Headlight Replacement: adım 8, 3 resimden 3.
    • Locate red tab on the headlight plug connector, and push it away from the headlight.
    • Firmly pull the connector away from headlight to remove.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Marco Santini
290 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-3, Green Fall 2015 Cal Poly, Team 17-3, Green Fall 2015 üyesi
CPSU-GREEN-F15S17G3
4 Üyeler
3 adet Kılavuz yazıldı
3 Yorum
Could Jeep make it more difficult to do simple maintenance? I doubt it!
Linda Procida - Yanıt
What is that green connector called? I’m having trouble putting new lights because none of the converters fit.
Alex - Yanıt
What it is the recommended torque to screw it back?
Luis Vitorio Cargnini - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 80
Her zaman: 20,416
