Ana içeriğe geç
2007-2012 Nissan Sentra Map Lights Replacement
Neye ihtiyacın var
  1. 2007-2012 Nissan Sentra Map Lights Replacement, Map Lights: adım 1, 3 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement, Map Lights: adım 1, 3 resimden 2. 2007-2012 Nissan Sentra Map Lights Replacement, Map Lights: adım 1, 3 resimden 3.
    • Use a spudger or opening tool to gently pry the lens out. Begin in the small space between the lens and console.
    • You should hear a small click when removing the lens from the console.
  2. 2007-2012 Nissan Sentra Map Lights Replacement: adım 2, 2 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #2 screwdriver, remove the 19.1 mm screw in the middle of the console.
    • Keep both the screw and the lens, from the previous step, in a secure location. You will need them both for reassembly.
  3. 2007-2012 Nissan Sentra Map Lights Replacement: adım 3, 2 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 3, 2 resimden 2.
    • Pry the console out gently from the ceiling of the vehicle by pulling it towards you.
    • If it is too tight to get your fingers in the space, use an opening tool to pry the console away from the ceiling of the car.
    • Don't yank the console away from the opening as it is attached by connectors.
  4. 2007-2012 Nissan Sentra Map Lights Replacement: adım 4, 3 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 4, 3 resimden 2. 2007-2012 Nissan Sentra Map Lights Replacement: adım 4, 3 resimden 3.
    • Rotate the bulb clip counterclockwise until it's loose to remove it from the console.
  5. 2007-2012 Nissan Sentra Map Lights Replacement: adım 5, 2 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 5, 2 resimden 2.
    • Gently pull the old lightbulb out of the clip.
    • Replace it with the bulb by gently pushing it in.
    • Avoid touching the bulb glass with bare hands as the oils and salts from your hands can damage the bulb and reduce the lifespan of the bulb.
  6. 2007-2012 Nissan Sentra Map Lights Replacement: adım 6, 2 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 6, 2 resimden 2.
    • Put the bulb clip back into console and turn it clockwise to secure it in place.
    • Repeat steps 4-6 afterwards for the other bulb.
  7. 2007-2012 Nissan Sentra Map Lights Replacement: adım 7, 2 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 7, 2 resimden 2.
    • Once you have repeated the same steps for the other bulb, gently place console back into its spot in the vehicle by pushing it in.
    • To ensure it is placed correctly, you should hear a small click when placing the console back into the vehicle.
  8. 2007-2012 Nissan Sentra Map Lights Replacement: adım 8, 1 resimden 1.
    • Make sure to test that the lights are working.
    • Once you have done that, put the 19.1 mm screw back in place with the Phillips #2 screwdriver.
  9. 2007-2012 Nissan Sentra Map Lights Replacement: adım 9, 2 resimden 1. 2007-2012 Nissan Sentra Map Lights Replacement: adım 9, 2 resimden 2.
    • Gently place the lens back into the console.
    • You should hear a "click" when the lens is placed securely in the console.
Sonuç
If all goes well, your car now has new bright map lights and you will now have the knowledge to perform future map light replacements for your 2012 Nissan Sentra. If this knowledge is forgotten, our guide will help provide you with proper instructions and indications on how to replace your map lights again. If you know of anyone with this model of car, and they need a replacement of their map lights, send this guide their way in order to assist them in the process of replacing their map lights. Like iFixit says, "if you can't fix it, you don't own it."
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 264
