Ana içeriğe geç
2007-2011 Toyota Camry Headlight Bulb Replacement
  1. 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: adım 1, 2 resimden 1. 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: adım 1, 2 resimden 2.
    • Pop up the hood of the car.
  2. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 2, 2 resimden 1. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 2, 2 resimden 2.
    • Locate the headlight bulb on the inside of the hood and hold onto the bulb.
    • The other headlight bulb is in the same area on the other side of the car.
  3. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 3, 2 resimden 1. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 3, 2 resimden 2.
    • Turn counterclockwise (1/4 of a turn) to remove the bulb and its attached plug from the socket.
    • This step is applied for both headlight bulbs.
  4. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 4, 2 resimden 1. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 4, 2 resimden 2.
    • Hold onto the bulb with one hand while holding down the clip at the bottom of the plug to remove the bulb.
  5. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 5, 2 resimden 1. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 5, 2 resimden 2.
    • Remove the new bulb from its package.
    • Make sure to not touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Wipe the bulb with a paper towel if contact was made.
  6. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 6, 2 resimden 1. 2007-2011 Toyota Camry Headlight Bulb Replacement: adım 6, 2 resimden 2.
    • Place the bulb back into the plug and press down until it click into place.
    • The bulb only goes in one way. Make sure the plug and the bulb are facing the same direction.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 48
Son 30 gün: 274
Her zaman: 13,108
