Ana içeriğe geç
2007 Honda Accord Bass Speakers Replacement
Neye ihtiyacın var
  1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: adım 1, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: adım 1, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement, Bass Speakers: adım 1, 3 resimden 3.
    • Use the plastic opening tools to remove the floor trim panel on the driver's side door.
  2. 2007 Honda Accord Bass Speakers Replacement: adım 2, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 2, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 2, 3 resimden 3.
    • Remove the shifter frame panel with the same opening tools.
  3. 2007 Honda Accord Bass Speakers Replacement: adım 3, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 3, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 3, 3 resimden 3.
    • Unclip the heated seats harnesses.
    • Remove the 12V power supply connection.
  4. 2007 Honda Accord Bass Speakers Replacement: adım 4, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 4, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 4, 3 resimden 3.
    • Remove the cubby space to access the head unit.
  5. 2007 Honda Accord Bass Speakers Replacement: adım 5, 2 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 5, 2 resimden 2.
    • Remove the center climate vents with the opening tools.
  6. 2007 Honda Accord Bass Speakers Replacement: adım 6, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 6, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 6, 3 resimden 3.
    • Remove the head unit from the dash.
  7. 2007 Honda Accord Bass Speakers Replacement: adım 7, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 7, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 7, 3 resimden 3.
    • Attach the wiring harness into the amp by clipping it in.
  8. 2007 Honda Accord Bass Speakers Replacement: adım 8, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 8, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 8, 3 resimden 3.
    • Run the wires under the back seat and along the driver's side door sill (removed in step 1) to under the steering wheel.
  9. 2007 Honda Accord Bass Speakers Replacement: adım 9, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 9, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 9, 3 resimden 3.
    • Drill a hole through the firewall located on the foot well of the driver's side under the steering wheel.
  10. 2007 Honda Accord Bass Speakers Replacement: adım 10, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 10, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 10, 3 resimden 3.
    • Run the power and ground wires from the trunk through the door sill and through the firewall to the engine bay.
  11. 2007 Honda Accord Bass Speakers Replacement: adım 11, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 11, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 11, 3 resimden 3.
    • Run the power wire where it will be out of the way.
    • Run the power wire (red) and the ground wire (green) to battery, connect red to positive and green ground to a clean piece of the car body.
    • Make sure to leave the power wire off until finished.
  12. 2007 Honda Accord Bass Speakers Replacement: adım 12, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 12, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 12, 3 resimden 3.
    • Remove the wiring harness from the back of the head unit.
    • Connect the four speaker wires and one remote wire to the harness as suggested in the owner's manual.
  13. 2007 Honda Accord Bass Speakers Replacement: adım 13, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 13, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 13, 3 resimden 3.
    • Clamp down the wire harness on the five wires.
    • Tape up the wire loom to keep it neat.
    • Insert the wire harness back into the head unit.
  14. 2007 Honda Accord Bass Speakers Replacement: adım 14, 3 resimden 1. 2007 Honda Accord Bass Speakers Replacement: adım 14, 3 resimden 2. 2007 Honda Accord Bass Speakers Replacement: adım 14, 3 resimden 3.
    • Put the head unit and the panels back into the car.
Sonuç
To reassemble your device, follow the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Frankie
253 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 35
Her zaman: 3,077
