Ana içeriğe geç
2007 Honda CR-V Brake Light Replacement
Neye ihtiyacın var
  1. 2007 Honda CR-V Brake Light Replacement, Brake Light: adım 1, 3 resimden 1. 2007 Honda CR-V Brake Light Replacement, Brake Light: adım 1, 3 resimden 2. 2007 Honda CR-V Brake Light Replacement, Brake Light: adım 1, 3 resimden 3.
    • Grab the handle in the middle of the trunk.
    • Use the handle to pull the trunk open.
  2. 2007 Honda CR-V Brake Light Replacement: adım 2, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the top and bottom screws.
  3. 2007 Honda CR-V Brake Light Replacement: adım 3, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 3, 2 resimden 2.
    • Pull back the tail light cover.
    • Hold it up; there are cords connected to the car inside.
  4. 2007 Honda CR-V Brake Light Replacement: adım 4, 3 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 4, 3 resimden 2. 2007 Honda CR-V Brake Light Replacement: adım 4, 3 resimden 3.
    • Untwist the faulty bulb counter-clockwise.
    • Pull the bulb out of the socket.
  5. 2007 Honda CR-V Brake Light Replacement: adım 5, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 5, 2 resimden 2.
    • Disconnect the bulb from the cord by popping it off.
  6. 2007 Honda CR-V Brake Light Replacement: adım 6, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 6, 2 resimden 2.
    • Pop in the Sylvania LongLife Mini Bulb 7443LL.
  7. 2007 Honda CR-V Brake Light Replacement: adım 7, 3 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 7, 3 resimden 2. 2007 Honda CR-V Brake Light Replacement: adım 7, 3 resimden 3.
    • Insert the bulb into the socket.
    • Twist the bulb in clockwise.
  8. 2007 Honda CR-V Brake Light Replacement: adım 8, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 8, 2 resimden 2.
    • Set the tail light cover back to the default position over the screw holes.
  9. 2007 Honda CR-V Brake Light Replacement: adım 9, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 9, 2 resimden 2.
    • Use a Phillips #00 screwdriver to screw in the top and bottom screws.
Bitiş Çizgisi
Dillon Laney
169 İtibar
1 Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 19
Son 30 gün: 62
Her zaman: 1,956
