Ana içeriğe geç
2007 Honda Civic Reverse Lights Replacement
Neye ihtiyacın var
  1. 2007 Honda Civic Reverse Lights Replacement, Reverse Lights: adım 1, 2 resimden 1. 2007 Honda Civic Reverse Lights Replacement, Reverse Lights: adım 1, 2 resimden 2.
    • Open the rear trunk and locate the reverse lights.
  2. 2007 Honda Civic Reverse Lights Replacement: adım 2, 2 resimden 1. 2007 Honda Civic Reverse Lights Replacement: adım 2, 2 resimden 2.
    • Insert a flathead screwdriver into the fastener.
    • Rotate the screwdriver counterclockwise until the fastener loosens.
    • Carefully remove the fastener.
  3. 2007 Honda Civic Reverse Lights Replacement: adım 3, 2 resimden 1. 2007 Honda Civic Reverse Lights Replacement: adım 3, 2 resimden 2.
    • Pull the lining away from the lights.
    • Carefully grasp the reverse light socket.
    • Make sure it is the correct socket; do not remove the other sockets, as those are your brake lights and turn signal lights.
    • Twist left to release the socket.
    • Slowly pull back from the socket to have access to the light socket.
  4. 2007 Honda Civic Reverse Lights Replacement: adım 4, 3 resimden 1. 2007 Honda Civic Reverse Lights Replacement: adım 4, 3 resimden 2. 2007 Honda Civic Reverse Lights Replacement: adım 4, 3 resimden 3.
    • Use a paper towel or rag to pull the socket back carefully and remove the light.
    • Do this for both sides when replacing the reverse lights.
  5. 2007 Honda Civic Reverse Lights Replacement: adım 5, 1 resimden 1.
    • Get your new reverse lights and install into each socket.
    • When installing, instead of pulling, push into the sockets and ensure they are locked in place.
  6. 2007 Honda Civic Reverse Lights Replacement: adım 6, 1 resimden 1.
    • Twist to the right and ensure it is locked into place.
Bitiş Çizgisi
Andrew Rodriguez
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 29
Her zaman: 71
