Giriş
This guide will detail how to replace the outer casing of a 2007 Toyota Highlander’s key fob, but can be used as a general guide on how to replace the outer casings of most car’s key fobs. Before performing the repair detailed in this guide, you should find the model’s replacement fob casing online. An example search could look like "[car make and model] [car year] key fob case." Make sure to compare measurements of your key case with the product description provided by the seller. Order this case, and when you have the replacement then perform the repair.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
