Ana içeriğe geç
2008 - 2020 Dodge Caravan Headlight Bulb Replacement
Neye ihtiyacın var
  1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement, Headlight bulb: adım 1, 1 resimden 1.
    • Park the car on a level surface.
    • Turn off the car and put on the emergency break for extra safety.
  2. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 2, 2 resimden 1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 2, 2 resimden 2.
    • Lift the hood release on the drivers side seat, near the foot pedals.
    • Open the hood latch and lift the hood up until it stays open on its own.
    • The headlight socket is located along inside edge of the hood.
  3. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 3, 3 resimden 1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 3, 3 resimden 2. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 3, 3 resimden 3.
    • At the rear of the headlight assembly, rotate the bulb in a counterclockwise direction to detach it from the socket.
    • Release the clips on both sides and take it out from the wiring harness.
    • Insert the new bulb into the harness. You will know it is complete when you feel the clips attaching.
    • Don't touch the bulb with your bare hands. The oils and salt from your hands will reduce the life of the bulb and possibly damage it.
  4. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 4, 1 resimden 1.
    • Align the tabs on the socket with the opening on the back to reinstall it.
    • Turn the socket clockwise to secure it.
  5. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 5, 2 resimden 1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: adım 5, 2 resimden 2.
    • Close the hood.
    • Test out your new lights.
    • To view the lights better, test them out at night.
Sonuç
To replace other lights, follow the same guide.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 83
Her zaman: 744
