Ana içeriğe geç
2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement
Neye ihtiyacın var
  1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement, Washer Nozzle: adım 1, 3 resimden 1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement, Washer Nozzle: adım 1, 3 resimden 2. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement, Washer Nozzle: adım 1, 3 resimden 3.
    • Unlatch the hood from the inside of your car.
    • If you're doing this right after driving your car, turn off the engine and let it cool down before working on it.
    • Put your fingers under the hood and lift the lever. With your other hand, raise the hood up.
    • The hood should rest on the support rod on its own; you can now remove the hand that was initially supporting the hood.
  2. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 2, 3 resimden 1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 2, 3 resimden 2. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 2, 3 resimden 3.
    • Remove all pins from the cover by firmly bending them out of the hood
    • You can use a mask to prevent inhaling dirt from the cover
  3. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 3, 3 resimden 1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 3, 3 resimden 2. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 3, 3 resimden 3.
    • Detach the pressure hose from the washer nozzle.
    • After detaching, examine the pressure hose for any debris that may have accumulated from the old washer nozzle.
  4. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 4, 3 resimden 1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 4, 3 resimden 2. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 4, 3 resimden 3.
    • Use pliers to compress the tabs that hold the nozzles in place.
    • The tabs will be located at the top and bottom of the nozzle from the hood.
    • Once compressed, firmly grip the nozzle at the top and pull it away
  5. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 5, 1 resimden 1.
    • Carefully insert the new washer nozzle into the top of the hood, applying gentle pressure until it snaps securely into place.
  6. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 6, 2 resimden 1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 6, 2 resimden 2.
    • After inserting the washer nozzle, double-check from inside the hood to ensure that the tabs are firmly gripping the hood
    • Re-attach the hose to the nozzle.
  7. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 7, 2 resimden 1. 2008-2016 Ford Fiesta Windshield Washer Nozzle Replacement: adım 7, 2 resimden 2.
    • To re-attach the cover push the pins on the cover into the coresponding holes
Sonuç
Mamoudou Balde
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 102
Her zaman: 248
