Ana içeriğe geç
2008-2013 Subaru Forester Engine Air Intake Filter Replacement
Neye ihtiyacın var
  1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: adım 1, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: adım 1, 2 resimden 2.
    • Make sure that the vehicle is turned off before you start.
    • Pull the hood release latch under the driver's dashboard to unlock the hood.
    • Press on the latch under the hood to expose the engine.
  2. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 2, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 2, 2 resimden 2.
    • Locate the engine air intake holding and hose.
  3. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 3, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 3, 2 resimden 2.
    • Unclip and separate the sensor and sensor cable on top of the holding.
    • Move the sensor cable to the side to prevent it from getting in the way.
  4. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 4, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 4, 2 resimden 2.
    • Unlatch the metal clips keeping the holding together.
  5. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 5, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 5, 2 resimden 2.
    • Use a 1/4" flat screwdriver to loosen the metal hose fastener on the engine air intake hose.
    • Do not remove the metal hose fastener. Keep the fastener on the hose for easy reassembly.
    • Remove the engine air intake hose from the holding.
    • Move the engine air intake hose to the side to prevent it from getting in the way.
  6. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 6, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 6, 2 resimden 2.
    • Separate the two sides of the holding from each other.
    • Remove the back panel of the holding to add space to remove the engine air filter.
  7. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 7, 2 resimden 1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: adım 7, 2 resimden 2.
    • Remove the old engine air intake filter from the holding.
    • Insert the new engine air intake filter into the holding in the same position as the old filter.
Sonuç
Julianna Sober
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 92
Her zaman: 2,559
