Ana içeriğe geç
2008-2013 Volkswagen Golf Tail Light Bulb Replacement
Neye ihtiyacın var
  1. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate tail light compartment: adım 1, 1 resimden 1.
    • On the driver's side of the vehicle's rear cargo area, locate the rectangular tail light compartment cover.
  2. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove cover: adım 2, 1 resimden 1.
    • Using your fingers, gently pull the cover away from the compartment.
  3. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb assembly: adım 3, 1 resimden 1.
    • With the cover removed, locate the light bulb assembly.
    • Use a flathead screwdriver to release the locking tab.
  4. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the light bulb assembly: adım 4, 1 resimden 1.
    • Pull gently to remove the light bulb assembly.
    • The assembly will remain connected to the vehicle via the wiring harness.
  5. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Locate the light bulb: adım 5, 1 resimden 1.
    • Turn the assembly so that the smaller tail light bulb and larger fog light bulb are visible.
  6. 2008-2013 Volkswagen Golf Tail Light Bulb Replacement, Remove the tail light bulb: adım 6, 1 resimden 1.
    • Using your fingers, gently pull the tail light bulb out of the socket.
    • Insert a new replacement light bulb into the tail light socket.
    • Excess force may cause light bulbs to break.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jeffrey Jacquin
284 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-12, Donnelly Fall 2014 USF Tampa, Team 1-12, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G12
1 Üye
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 92
Son 30 gün: 371
Her zaman: 46,353
