Ana içeriğe geç
2008 Ford F-150 Air Filter
Neye ihtiyacın var
  1. 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: adım 1, 2 resimden 1. 2008 Ford F-150 Air Filter, 2008 Ford F-150 Air Filter: adım 1, 2 resimden 2.
    • Turn the engine off.
    • Pull the lever to release the hood.
    • Open the hood.
  2. 2008 Ford F-150 Air Filter: adım 2, 3 resimden 1. 2008 Ford F-150 Air Filter: adım 2, 3 resimden 2. 2008 Ford F-150 Air Filter: adım 2, 3 resimden 3.
    • Find the filter housing unit.
    • Pull the leaver to release the clamp.
    • Move the housing unit out of the way to free the filter.
  3. 2008 Ford F-150 Air Filter: adım 3, 2 resimden 1. 2008 Ford F-150 Air Filter: adım 3, 2 resimden 2.
    • Remove the filter by pulling it straight out.
    • If you are replacing the filter completely, skip to step 7 after completing this step.
  4. 2008 Ford F-150 Air Filter: adım 4, 1 resimden 1.
    • Hit the filter with hand, or on the ground, to remove any large particles that are stuck in the filter.
  5. 2008 Ford F-150 Air Filter: adım 5, 2 resimden 1. 2008 Ford F-150 Air Filter: adım 5, 2 resimden 2.
    • Get a hose with running water.
    • Guide the hose inside the filter, pushing out all the smaller particles.
    • This step will take about 15 minutes, go slow.
  6. 2008 Ford F-150 Air Filter: adım 6, 2 resimden 1. 2008 Ford F-150 Air Filter: adım 6, 2 resimden 2.
    • Place the wet filter outside for it to air dry.
    • Placing the filter in direct sunlight will allow the drying to happen quicker.
  7. 2008 Ford F-150 Air Filter: adım 7, 1 resimden 1.
    • When the filter is completely dry, replace the filter in the housing unit.
  8. 2008 Ford F-150 Air Filter: adım 8, 3 resimden 1. 2008 Ford F-150 Air Filter: adım 8, 3 resimden 2. 2008 Ford F-150 Air Filter: adım 8, 3 resimden 3.
    • Resemble the housing unit and close the hood.
Sonuç
To install a new air filter follow steps 1-3 to remove the old filter and steps 7-8 to install the new air filter
Brennan DuBose
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 320
