Ana içeriğe geç
2008 Honda Fit Inner Door Grip Replacement
  1. 2008 Honda Fit Inner Door Grip Replacement, Inner Door Grip: adım 1, 1 resimden 1.
    • Park the car on a level surface and engage the parking brake.
  2. 2008 Honda Fit Inner Door Grip Replacement: adım 2, 2 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 2, 2 resimden 2.
    • Open the door to access the interior door panel. Remove any dirt or tape from the door handle.
    • Remove the taped or broken inner door handle from the inner door panel of the car.
  3. 2008 Honda Fit Inner Door Grip Replacement: adım 3, 3 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 3, 3 resimden 2. 2008 Honda Fit Inner Door Grip Replacement: adım 3, 3 resimden 3.
    • Retrieve the door grip and hook the door grip to the panel by the hook that is attached to the door panel.
  4. 2008 Honda Fit Inner Door Grip Replacement: adım 4, 2 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 4, 2 resimden 2.
    • Once the door grip is hooked to the door panel, the door grip will hang.
  5. 2008 Honda Fit Inner Door Grip Replacement: adım 5, 3 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 5, 3 resimden 2. 2008 Honda Fit Inner Door Grip Replacement: adım 5, 3 resimden 3.
    • Starting with the right side, adjust the door grip to the claw attached to the door panel's right side.
    • Push the door grip gently.
  6. 2008 Honda Fit Inner Door Grip Replacement: adım 6, 3 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 6, 3 resimden 2. 2008 Honda Fit Inner Door Grip Replacement: adım 6, 3 resimden 3.
    • Push the door grip to the claw attached to the door panel to lock the door grip so it attaches.
  7. 2008 Honda Fit Inner Door Grip Replacement: adım 7, 3 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 7, 3 resimden 2. 2008 Honda Fit Inner Door Grip Replacement: adım 7, 3 resimden 3.
    • Insert the door grip into the center of the door panel that has two holes.
    • Make sure the centerpiece of the door grip is aligned with the center holes of the door panel for it to attach properly.
  8. 2008 Honda Fit Inner Door Grip Replacement: adım 8, 2 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 8, 2 resimden 2.
    • Push the door grip to the claws on the top center of the door panel so it attaches.
  9. 2008 Honda Fit Inner Door Grip Replacement: adım 9, 3 resimden 1. 2008 Honda Fit Inner Door Grip Replacement: adım 9, 3 resimden 2. 2008 Honda Fit Inner Door Grip Replacement: adım 9, 3 resimden 3.
    • Finally, press the left side of the door grip to the far left of the door panel to align with the door clips so that it holds the left side balancing the right.
  10. 2008 Honda Fit Inner Door Grip Replacement: adım 10, 1 resimden 1.
    • Once each side of the door grip is attached to the door panel the inner door grip/handle is fixed.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 80
Son 30 gün: 106
Her zaman: 1,478
